Nice work! Now, you can put anytime a fan to reduce more heat.
I have a similar solution in my mind, but I cannot find, yet, a thermal pad with double adesive.
That's exactly the brand I tested it on. (a very recent tomtop one though, it came with 20170627 firmware)
Do you updated it with the SD card method? Had you seen any differences running the update? And the last question. Are all those specific boxes having the same hardware?
