Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
set a low heat stirling engine on top to displace the heat
https://www.youtube.com/watch?v=sFJ-JnVSfiQ
Using applications such greenify or root booster, can reduce the use of cpu... mine is working at 5% in idle with firm 08.03 with this apps.
The temps can be measured real time with cputemp app.
But we must remember that the device lacks ventilation and is almost hermetically closed, the best way to improve temps is modding.
Originally posted by plumber View PostUsing applications such greenify or root booster, can reduce the use of cpu... mine is working at 5% in idle with firm 08.03 with this apps.
But still it should be ok from stock without the need to add extra apps!
Well i already started modding, modded DVFS now all 8 cpu cores are at 1.5ghz instead of 4 at 1.5ghz and 4 at 1ghz and oced a bit the gpu from 666mhz to 792mhz!
And other little tweaks, but still needs lots of work!
Hola, intente actualizar a android 7.1 mediante Burn_Card_Maker y una tarjetas microSD. Todo iba bien y me salio la pantalla de upgrading, el problema viene cuando cambie la tv de canal y al volver no se veía imagen y ahora enciende el dispositivo pero no hay imagen. He probado pulsando el boton recovery pero no funciona ¿alguna solución?
Hello, try upgrading to android 7.1 using Burn_Card_Maker and a microSD card. Everything was fine and I left the screen upgrading, the problem comes when I change the channel tv and when I did not see the image and now turn on the device but there is no picture. I tried it by pressing the recovery button but it does not work any solution?
Originally posted by Unbrick View PostHola, intente actualizar a android 7.1 mediante Burn_Card_Maker y una tarjetas microSD. Todo iba bien y me salio la pantalla de upgrading, el problema viene cuando cambie la tv de canal y al volver no se veía imagen y ahora enciende el dispositivo pero no hay imagen. He probado pulsando el boton recovery pero no funciona ¿alguna solución?
you must use usb a to usb a to upgrade again using the program running in windows. or using some totorial to upgrade again with the card. did you tried reset the d'eviced, can you see the recovery menu?
tendras que utilizar un cable usb a to usb a para actualixarlo de nuevo mediamte el programa de actualizacion en windows. o seguir algun tutorial para hacerlo de nuevo con la tarjeta. has probado a resetear el aparato, llegas a ver el menu de recovdery?
Thanks for your answer. I do not get any image and through the pc I do not detect it and I tried it on two different pc's. I think I would need the firmware stock but the zip with the file uboot.bin ect but I can not find it
There are currently 4247 users online. 0 members and 4247 guests.
