Sent from my U65GT using Tapatalk
Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
Originally posted by leotzian View PostDo you updated it with the SD card method? Had you seen any differences running the update? And the last question. Are all those specific boxes having the same hardware?
From what I've read and seen, there's probably no difference at this point. For example, I had a 4K version a month ago which came with the two internal USB ports, which was only supposed to be found inside the Alfawise version. No guarantees though
Originally posted by JoseM View Post
you mean the wireless update app is malware right ?
Originally posted by Shimon
It's not an update but a full image so you have to flash it via the Burn Card Maker or USB Burn Tool methods.
Yes, see the first 2 pages of this thread.
I am afraid not to brick it...
Sent from my Redmi Note 4 using Tapatalk
Originally posted by ShimonI used the Burn Card Maker method, having checked the "erase bootloader" option. These stock roms don't start flashing otherwise.
Thanks friend I will come back if I want something else.
Originally posted by erpenstine View PostHi There
I have the H96 Pro Plus, 3Gb DDR3 / 32GB Generic TV Box, I have an issue getting my box to see my LAN connection, only after I reboot the TV Box does it see it, I have to do this every day, anyone else have this issue?
Originally posted by Shoestring View Post
Yes mine does the same thing. I have 7.1.1 on it right now but I see 7.1.2 is available. Not sure if 7.1.2 addresses this or not though
i need to disconnect and connect the LAN cable to get it working.
Originally posted by muncheno View Post
Same as mine H96pro plus too. LAN disconnected whenever I reboot my router.
Quick mod if your getting heat issues mines running fine after making top vent. Knife screen and double sided tape and done. I moved wifi and put heat sink on with thermal compound so its now not over heating with anything ive thrown at it. Took about 10 minutes to drill out lid opening for screen. Maybe 20 minutes all in.
Not the cleanest cuts ive done but its not noticed once lids back on.
Quick way to cool it down though.
Thanks to trebor for showing that part pops off.
Originally posted by Shimon View PostHere's a proper version of the full Android 7.1.2 ROM dated 20170809 (usual launcher, device identified as H96Pro+ instead of just S912, rooted):
aml_7.1_s912_q9377-S912_KDMC_mac-20170809
https://mega.nz/#!ZTIGWABC!xgkGFOrWL...8XYdisAlwcb2WY
"Wireless update" is malware as usualUninstall without running!
Please, more details...
I hope you put this post in right topic, but, to be sure, please confirm.
2/16gb and 3/32gb
I plan to upgrade the heatsink on mine. Which would be better 38mm x 38mm x 6mm or 40mm x 40mm x 11mm https://www.amazon.com/BNTECHGO-Aluminum-Heatsink-Cooling-Silicone/dp/B01IQOAJBQ/ but cut down to 7mm height? I kind of like the 40mm design better but the 38mm will fit without any modifications.
There are currently 2681 users online. 0 members and 2681 guests.
