Credits to Super Celeron for his Awesome work on these 912 devices. This is not his work so any questions re problems or concern should stay in this Thread.
A912 Mod of Super Celeron Firmware
I modified the firmware to work with a912 (6255). Wifi and bluetooth working. I only have img file so you have to use USB burning tool. https://dl.dropboxusercontent.com/u/...ron%20a912.img
Originally posted by frasse View PostI modified the firmware to work with a912 (6255). Wifi and bluetooth working. I only have img file so you have to use USB burning tool. https://dl.dropboxusercontent.com/u/...ron%20a912.img
hmm the ones that say that have 9377 chip on a A912 serial, i think the only way you guys have to confirm it, is open it.... i understand if you guys dont feel that is good to open it!
But you should have made another thread, like "Modded superceleron rom for GT1 A912/6225"
Well looks like i dont need to finish mine.
I hope he continues is mod when i make another rom
Originally posted by Sleep View Post
thnx! Can you share the method that you use to build/port this rom to a912 device?
Originally posted by frasseI modified the firmware to work with a912 (6255). Wifi and bluetooth working. I only have img file so you have to use USB burning tool. https://dl.dropboxusercontent.com/u/...ron%20a912.img
Awesome job man..... Works great without problems so far
Sent from my EVA-L19 using Tapatalk
I am using it five days and must say that it works very well...if you continue that you develop rom, I suggest you add option in display - RGB mode, I see that it comes with the latest fw for Yoka KB2 or Mecool BB2 or other ...and was part of the previous roms for 905 chips...in any case, thanks for the effort ... a great job you've done ...
Originally posted by superceleron View Posthmm the ones that say that have 9377 chip on a A912 serial, i think the only way you guys have to confirm it, is open it.... i understand if you guys dont feel that is good to open it!
Great workI wanted to ask if in that rom the flashing green on screen and the wi fi problems are fixed? Cause I'm having issue with wi -fi which I really hate, sometimes when i turn on the box it's not connected and i gotta go crazy and remove and set again connection more than once to make it work
There are currently 2570 users online. 2 members and 2568 guests.
