do you know an other program?
A912 Mod of Super Celeron Firmware
Originally posted by Paprika95 View Postfirst you have to delete the blanks in the file name. and please show me the settings. and maybe you have not choose the right sd card the a: is not your sd card please choose another one in the box.
You can replace the blanks with a dash.
i tink it only wants to use my C drive. (internal SD)
Originally posted by superceleronOk do this... using root explorer or any other explorer go to /system/etc/wifi and inside wifi see if you have this folders "firmware" inside this one should be wlan folder and some files all with 30 in the name.
Then go inside wlan folder and inside should be this files cfg.dat, qcom_cfg.ini and qcom_wlan_nv.bin.
If yes then you can use my rom since its a 9377 variation!
Gesendet von meinem SM-G930F mit Tapatalk
OK ... dumb question again .. .before i do somting stupid.
I managed to create a SD disk on an other computer!
It was only possible as extfat, not FAT32. (if this is a problem, i need to find an other SD).
But what to do now? Go to Recovery, using the pinlock trick? ... And then? :S (before i do something stupid)
*edit
OK FAT32 did the trick!installing now!!!
yay, all is working perfectly! Thanx for the help, and compiling this build!!ÂÂLast edited by maurits82; 10 January 2017, 11:46.
Originally posted by rukmal12 View PostThis rom works on alfawise h96 pro+ devices ?
regards,
kabise
Originally posted by kabise View Post
Thanks Kabise .. I might be wrong I thought that is for h96 Pro version not for Pro + ?
Originally posted by superceleron View PostNo it wont work on that box, this and the original rom of mine are only for the Beelink GT1 and Alfawise S92... So dont try it or you may brick your device!
There are currently 2949 users online. 0 members and 2949 guests.
