A912 Mod of Super Celeron Firmware
just a question: how does it open a S912 firmware?
The firmware on my Tv Box has dat extension...
Here the list of files:
boot.img
bootloader.img
dtb.img
file_contexts
logo.img
recovery.img
system.new.dat (about 743 MB)
system.patch.dat
system.transfer.list
With customization tools 2.0.8 gives me a error.
Originally posted by LimonnetJust a simple question from a noobi. I got the gt1 6 days ago, and got and OTA updated 109MO on the firt run. Been using mostly on kodi and found no of the mentioned problems of dark screen on kodi and my wifi its very smooth with no disconection.
I undestand that the celeron ROM it was used to fix theese problem os earlier GT1 original ROM.
As the 109MO seems to run very smooth with no bugs, i think there is no need to install celeron, unless you guys tell me otherwise and can point out other advanges other than fix the old problems
I also have the box, and i have updated to superceleron room. One of the most obvious reasons is to boost the box speed. The room is lighter, and runs smoother. At least that is mine experience with the mod.
But if you are happy with the stock room, stay with that one.
Enviado do meu K013 através de Tapatalk
Originally posted by McFreakens View Post
Hi there
Hi there
Enviado do meu K013 atravs de Tapatalk
frasse Can you take his V7 rom and add the same wireless drivers you added to this version, or could you send him the wireless drivers for the 6255 wireless card so he can add to his v8? superceleron what do you think? If he sends you the drivers for the 6255, can you put them into v8 of your ROM?
There are currently 3078 users online. 0 members and 3078 guests.
