A912 Mod of Super Celeron Firmware
Originally posted by frasse View PostI modified the firmware to work with a912 (6255). Wifi and bluetooth working. I only have img file so you have to use USB burning tool. https://dl.dropboxusercontent.com/u/...ron%20a912.img
But the download stops at 314/641 MB every time I try and download it...
Originally posted by Sleep View PostI have no problems with wifi, and settings are from stock rom. Open the box and check conection between board and antena. My next project would be solidering old laptop wifi antenna to the board.
With the stock firmware 104, 106 the WiFi is desperately slow - too slow to even load the Google home page.
With your firmware I get an issue where the WiFi keeps disconnecting... i have been unable to test speed...
I do have another (broken) Gt1 I wonder if I should drop the board into it and see if it is an antenna issue...?
I've installed your image and I recognized, that supercelerons init.d script br1fix will not be executed (located in /etc/init.d). It seems to be that the excecution right on this script is missing ?
It has r r r permission but should have -rx-rx-rx I think ? The script solves the 'dark screen issue' on stock rom.
There are currently 1097 users online. 0 members and 1097 guests.
