Nexsmart D32 Modded Firmware (Will also work on Dolamee D5)
it doesn't matter, if i put the box in standby mode in 10.00 pm , if i return in 2.00 am the box will still show 10.00 pm , but if i reboot it will show correctly 2.00 am. the internet comes from ethernet and works perfectly after standby mode or after reboot.
thank you anyway for your answers.
I've done some digging around but haven't really come up with anything that answers the question.
Can you give this app a try and see if it has any effect?
https://play.google.com/store/apps/d...=search_resultR-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bill30 View PostYes is the only app that helps after a minute it corrects the time, but I was hopping to avoid it, anyway thanks for your help.
There are currently 1488 users online. 0 members and 1488 guests.
