Nexsmart D32 Modded Firmware (Will also work on Dolamee D5)
After the precious help of bluesmanuk finally i flashed my Nexsmart D32.
i'm still testing but the first impression are:
- Fastest to switch on and the launcher.
- More options to setting (i didn't try the auto framerate adjust)
- Youtube lagging with sound issues
- Skype unusuble with sound and video issues.
I think this issues are related with the lack of network tweaks in Stock Firmware, because the issues are all with apps using network streaming. It's just a guess.
Do you think is possible repair?
I'm using Ethernet connection with a Cat.6 cable and with a 120mb Speed, and other users have the same issues, so is not because my home netowrk.
I disable some apps like you suggested, but the issues continue.
I have another cheap TVbox Beelink X2 and i haven't no issues with skype, youtube.
Many Thanks
Beelink X2 and Nexsmart D32 for now!!!
Originally posted by bluesmanuk View PostI'm not getting any lagging in Youtube or other streaming apps such as iPlayer
I disable all user apps from running at startup and some system ones that are unnecessary.
Which ones have you disabled?
Hi bluesmanuk canon you please upload the drivers you used or the detail a bit the process od nexsmrt d32 because i can't get my pc to recognize it and I had installed some firmware on RK30xx with batch-tool but this device is always unrecognised. The android tool doesn't find the device either. I use a cable usb male to male and connect it to the usb near the rear side and the device is installed as unknown, after I change to rockchip drivers the device insn't recognized by the firmware upgrade tools.
Originally posted by fabioaos View PostHi bluesmanuk canon you please upload the drivers you used or the detail a bit the process od nexsmrt d32 because i can't get my pc to recognize it and I had installed some firmware on RK30xx with batch-tool but this device is always unrecognised. The android tool doesn't find the device either. I use a cable usb male to male and connect it to the usb near the rear side and the device is installed as unknown, after I change to rockchip drivers the device insn't recognized by the firmware upgrade tools.
Fire up the tool and load the firmware from the Upgrade Firmware tab.
You don't need AC power at this stage as enough juice will be delivered from your PC.
Using a toothpick or something similar and insert it into the rear AV port and whilst the reset switch is pressed in, plug the USB cable into the port nearest the back of the box (the other end should already be plugged into your PC at this point, USB2 port preferable to USB 3). Release the toothpick from the reset button after a couple of seconds.
The status of the Android tool should go from no devices found to indicate that it can be seen.
Select the EraseFlash option in the tool and wait for it to be complete.
Then select the Upgrade option and wait for the process to complete.
Whilst it is updating you can plug the AC adapter in of you want.
The box will reboot and start the process of completing it's installation during which point you will be asked if Google can check for harmful apps, which you should agree to, or else it will come up with the prompt every time that it installs one of the apps in the background.
Download link to the driver installer and tool is
https://www.dropbox.com/s/h98fuo2ddvy1xhg/AndroidTool_Release_v2.33.zip?dl=0R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
You can get the stock firmware here.
https://mega.nz/#!p1A1iL6I!lhNGsmAKY9TjjyNnn1UHPa9ktOvWsyucZmAzbUg AXc4R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
If you want the manufacturers to provide an update path to Marshmallow, this seems to be the official place to request it.
http://www.tvboxforum.com/showthread.php?tid=1003R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
hey guys. i followed bluesmanuks instructions for installing this rom. so after installing the driver, opening the androidtool, loading the firmware into androidtool and plugging in the box with the button pressed, windows always recognizes the box for like 5 seconds as unknown device and then it disappeares again from hardware manager.. did i do something wrong at the driver installation step or do you think i should order a new usb cable?
thanks
There are currently 2677 users online. 0 members and 2677 guests.
