Nexsmart D32 Modded Firmware (Will also work on Dolamee D5)
Originally posted by bluesmanuk View PostI have just seen that there will be an official MM firmware for the D5 in a couple of weeks, so that is good news.
So I don't need to do any more right now and will wait and see what they come up with but can say that FTMC, Youtube and other things that I have tested all work very well.
MM is a little more resource hungry than Loppipop, so is a little sluggish at the start, so optimisation is even more key to smooth video playback.
Where was this claim for the MM update found?
With just a couple of weeks to go, it will be worth waiting for something official that can then be tweaked.
Plus I don't have the proper spdif cable to hook up to test the audio sync issue with Netflix on the ugoos firmware. So my only hope is the update comes before the cut off return date for Amazon.
If it doesn't I'll have to return this box and either wait or try to find another similarly price box out there!
bluesmanuk Hey I was just wondering where did you see "there will be an official MM firmware for the D5 in a couple of weeks," I was hoping to read up and follow it.
Originally posted by tacotime82 View Postbluesmanuk Hey I was just wondering where did you see "there will be an official MM firmware for the D5 in a couple of weeks," I was hoping to read up and follow it.
http://www.tvboxforum.com/showthread.php?tid=1200R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostIf I had a Netflix account I would test it on my MM build just to see.
Originally posted by ImCrafted Wrote ,,I have the audio sync solution for the Dolamee D5 here, posting seeing as this was an issue for me and it seems as a true solution was never posted in this thread.
On the Dolamee D5 access Settings > Prefrences > More setting > Device > Display > HDMI Mode > 1920x1080p-24
The above option will sync the netflix audio properly. Let me know if this solves the problem for you, it did for me!
I thought this might be some usefull info for everyone.
I have been digging around for the Netflix issue resolution and found the following.
I found this over at http://www.tvboxforum.com/showthread.php?tid=789&page=2
There are currently 1469 users online. 0 members and 1469 guests.
