[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Just posted a new release that fixes the issue with the Android TV Play Store (PhoneskyKamikazeCanvas) incorrectly upgrading apps to versions not designed for Android TV.
Originally posted by Magendanz View PostFor the remote, all you need to do is transplant the remote.conf file in /system/etc. If you don't still have it, here's a link for the Nexbox A95X.
Originally posted by Magendanz View PostJust posted a new release that fixes the issue with the Android TV Play Store (PhoneskyKamikazeCanvas) incorrectly upgrading apps to versions not designed for Android TV.
It is possible to check if the formats eac3, dts, dolby are well tuned because I have this passtrough problem that I did not have with the official firmware r106
Originally posted by Magendanz View PostI've actually got one of the Beelink Mini MXIII boxes too, but I've been focused on Android 6.0.1 and later so that I could roll out a no-compromise Android TV experience. While ATV did exist for Lollipop, it wasn't really all that mature. Let me grab that old box (that's currently with my in-laws) and take a fresh look, now that things are settling down with the S912 and S905X builds. Maybe we could make it work.
Well some feedback from last day on my 905X devices :
- My Tanix TX Pro5 (Bedroom :-) )
Wifi OK
BT OK
No special issues for the moment, Mycanal, Molotov (french TV) running smooth, voice recognition OK
- Nexbox A95X :
Wifi OK
BT NOK
So aside the wireless driver issues (always same problem :-) ) this is a very appreciated Rom, especially by my colleagues who want me to flash their boxes with.
Originally posted by XuanLee View PostHi all,I'm using the Tanix TX5. I can not be switched on by pressing the power on remote. How to fix? Thanks
http://freaktab.com/forum/tv-player-...431#post632431
Originally posted by Cinquieme View Post
It's here, you have to replace the right remote.conf :
Oh yes i had that with an elder Frankenstein ROM also.
The issue is adressed somewhere in the forum
I can't remember if there was any solution.
I'll check my TX5pro tonight
[Edit] : FRAK ! Same for me :-( I hadn't noticed because my domotics powers on the wallplug.
Sso indeed some setting in this firmware is not compliant with other boxes than the Minis ...Last edited by Cinquieme; 28 February 2017, 18:08.
Originally posted by Cinquieme View PostOh yes i had that with an elder Frankenstein ROM also.
Guest
There are currently 2849 users online. 1 members and 2848 guests.
