[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Rainer Trunk is actually putting together an app that will include all the most popular remote.conf files, along with some photos. The idea is that on a rooted machine you can just pick your remote by appearance, and the app will install the correct file in your custom ROM.Last edited by Guest; 04 March 2017, 00:34.
Originally posted by Magendanz View PostRainer Trunk is actually putting together an app that will include all the most popular remote.conf files, along with some photos. The idea is that on a rooted machine you can just pick your remote by appearance, and the app will install the correct file in your custom ROM.
can you give a sign when the .apk is working? Thank youLast edited by EagleEyeXZ; 03 March 2017, 16:44.
Guest
Originally posted by XuanLee View PostI want to again root ROM how do?thanks!
Guest
Originally posted by f4tal View PostEverything is working smoothly but I can't power the box on from the remote. Unplugging and plugging power back on works okay. Any idea how to fix this? Appreciate your work mag!
Guest
f4tal , would you be willing to help me with an experiment? Could you manually flash the original OEM bootloader from your Nexbox a95x? You'd just need to open Terminal Emulator, navigate to the bootloader.img file, type "su" and grant superuser privileges in the SuperSU dialog, then type "dd if=bootloader.img of=/dev/block/bootloader. Then, reboot and see if the power button on your remote works again.
You shouldn't do this unless you have a male-to-male Type A USB cable handy so that you can flash the Amlogic burn package if it doesn't work.
Originally posted by Magendanz View Postf4tal , would you be willing to help me with an experiment? Could you manually flash the original OEM bootloader from your Nexbox a95x? You'd just need to open Terminal Emulator, navigate to the bootloader.img file, type "su" and grant superuser privileges in the SuperSU dialog, then type "dd if=bootloader.img of=/dev/block/bootloader. Then, reboot and see if the power button on your remote works again.
Guest
Originally posted by f4tal View PostDo I get the factory bootloader from the factory image?
Originally posted by Magendanz View PostHere you go: NEXBOX-A95X_bootloader.zip
There are currently 2847 users online. 1 members and 2846 guests.
