[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by newcastle View PostMy TV Philips 2015 of release, at connection on hdmi there is a green background for some seconds.
Originally posted by Magendanz View Post
That's the RGB fix, which is in the Beelink firmware but not this one. This weekend I'm planning to rebase this custom ROM on the latest Beelink Mini MX3 II OEM firmware, and that should address the RGB problem as well as several other issues.
Guest
Originally posted by Fenderman View PostWhen I play movies in the Kodi app for Android TV it seems to be darker than usual. Especially in dark scenes. Is this issue part of this formbare and can it be fixed?
Guest
As promised, I rebased this custom ROM on the latest Beelink Mini MX3 II release (v110M0). This should resolve issues with formatting SDs for internal storage, RGB output to Sony and Philips TVs, and gets us the improved SystemUI navigation bar and shutdown UI. Since this SKU ships with the Qualcomm QCA9337, the wireless updater is now for the AMPAK chipsets, which includes drivers and firmware for the following: 62X2, 4353, 4356, 6212, 6255, 6330, 6335, and 43458. The update also substitutes a generic Amlogic S905X logo splash for the Beelink logo.
I've tested the wireless updater on the Mini M8S II, but haven't yet tried other AMPAK boxes. If you are willing to test on one of these others, please let me know the results.
Update: It seems that other chipsets that are Broadcom BCM43xx knock-offs are also working with the AMPAK update. I have a report that the Realtek RTL8189ES has functional WiFi, but not Bluetooth. When in doubt, I'd say it's worth giving the updater a try.
Guest
Just a quick note: If you install the AMPAK update, the Mini M8S II kernel changes the power button behavior. Instead of the pop-up menu (Suspend, Shutdown, Reboot), you'll suspend with a normal press and bring up a shut down confirmation dialog with a long press. (This is unlike on the Mini M8S II, where a normal press of the power button shuts down immediately with no confirmation dialog.) I actually prefer this behavior and am working to make it consistent across both kernels.
[QUOTE = Magendanz; n636103] Chỉ cần một lưu ý nhỏ: Nếu bạn cài đặt bản cập nhật AMPAK, hạt nhân Thống M8S II thay đổi hành vi nút nguồn. Thay vì trình đơn pop-up (Suspend, Shutdown, Reboot), bạn sẽ đình chỉ với một nền báo chí bình thường và mang đến một hộp thoại xác nhận đóng cửa với báo chí dài. (Điều này là không giống như trên Mini M8S II, nơi báo chí bình thường của nút nguồn tắt ngay lập tức không có hộp thoại xác nhận.) Tôi thực sự thích hành vi này và đang làm việc để làm cho nó phù hợp trên cả hai hạt nhân [/ QUOTE].
Bản ROM: Beelink MX3 II / M8S II Series TVStock Nexus ROM (Android TV) works normally on Box Tanix TX5?
There are currently 2605 users online. 1 members and 2604 guests.
