[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by GliTch04 View PostI'm looking at buying a nansii T95K Pro Android TV Box Amlogic S912 , would this rom work for this application or would it need a completely different build
Guest
I'm not sure why you'd want to uninstall TWRP, but you can revert to the stock S905X recovery in Terminal Emulator. Just download this file, open the terminal window and navigate to the directory that contains the file, type "su" and grant superuser permissions in the SuperSU dialog that pops up, then type: "dd if=recovery_S905X.img of=/dev/block/recovery". When it's done, you can type "reboot recovery" to confirm that you've now got the stock recovery.
Originally posted by Magendanz View PostI'm not sure why you'd want to uninstall TWRP, but you can revert to the stock S905X recovery in Terminal Emulator. Just download this file, open the terminal window and navigate to the directory that contains the file, type "su" and grant superuser permissions in the SuperSU dialog that pops up, then type: "dd if=recovery_S905X.img of=/dev/block/recovery". When it's done, you can type "reboot recovery" to confirm that you've now got the stock recovery.
Hello,
I would like to install this ROM on my Nexbox a95x but all I get in TWRP is error 7: the zip file is not meant for my device.
Am I missing something? Since there is no .zip file for the nexbox a95x in the download section
edit: Nevermind, I misread something, my badLast edited by nawrejin; 02 March 2017, 19:13.
Guest
Originally posted by XuanLee View PostI want to watch myK+ service of VietNam. Thanks!
Guest
Originally posted by nawrejin View PostI would like to install this ROM on my Nexbox a95x but all I get in TWRP is error 7: the zip file is not meant for my device.
Originally posted by Magendanz View PostWell, the new OTA updates are designed to be incremental updates, and so I check for the expected product.device (e.g. "p212") and build.id (e.g. "MHC19J"). These are different on the NEXBOX A95X, basically because they decided to change them in the build.prop rather than just going with the Amlogic defaults. Regardless, you should always start with a "clean install" using the Amlogic burn package and USB Burning Tool or BootcardMaker. After that's done, the OTA updates should suffice (and they won't wipe user data).
I suppose I could change the updater-script to my desired product name, but instead I'll get myself a male-to-male USB cable tomorrow.
Thank you for clarifying, sir.
Guest
Originally posted by nawrejin View PostI suppose I could change the updater-script to my desired product name....
There are currently 2633 users online. 1 members and 2632 guests.
