[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by XuanLee View PostHow to sign .img to .zip make flash through OTA Updater or TWRP? Thanks!
Just installed this version during the weekend, seems to work nice. Thanks for all effort!
But seems like I have some problems with audio pass trough, (which was the reason to change from stock rom) I couldn't find anything about it in this thread.
I have a dolby digital and DTS compatible receiver. But even when setting pass trough it doesn't receive the bit stream wit Kodi. When setting SPDIF-setting for dolby digital it works and dolby digital shows up in the display (even trough HDMI). When I plays DTS I get no sound at all. If I connect to the TV I get sound when disabling pass trough, but to the receiver I don't get anything.
With MX-player I receives DTS sound for the same movie I tried in Kodi (but DD doesn't work for the movie that worked in Kodi..)
Does this build support IEC pass trough for Android? Or isn't it even supported by Amlogic S905X?
Thank in advance, It's always so tricky to get DD and DTS pass trough work.
Guest
Originally posted by kenshi View PostHello. I am installed firmware and unable to use cast service, for example cast video from youtube app from android. It should not work or there are some subtleties?
Originally posted by Magendanz View PostThat's a known issue. Check the Known Bugs section in the original post for more details.
Guest
Originally posted by kenshi View PostI mean that i can stream video from default youtube app. At this moment at window where i can choose device where i need to stream i seen two devices with the same name, but only one of them worked.
(I need to capture a logcat when that happens so that I can look closer at how it got a cast device cert.)
EagleEyeXZ version 16.6 16.6.0 (2017/03/01) http://spmc.semperpax.com/- ADD: “Visible behind” for Android TV
- ADD: “Now playing” for Android TV
- FIX: HD audio IEC on N (Shield + Mi)
- FIX: use PT RAW for re-encoding if selected- FIX: 3D -> 2D in amcs
- FIX: windowed amc
- ADD: Dynamic amcs surfaces
- FIX: amcs rotation
- FIX: plugin cache
- ADD: zeroconf via API
- FIX: 4K GUI
- FIX: High CPU load
- ADD: Smoothstreaming
- FIX: crash on exit with NFS
Hello,
As I said in another topic, I've tried to install MINIMXIII-II_110M0_TVStock-20170319.img from an SD card with Amlogic Burn Card Maker but the upgrading screen is always stucked at 5% of the progress bar.
I've also tried with Amlogic USB Burning Tool but to no avail.
I get the following errors:
- [0x30201006]UBOOT/Disk initialize/Send command/Time out
- [0x00101004]Erase bootloader/Lowper/Identify/Error result
- [0x10101002]Romcode/Initialize DDR/Identify/USB Control setup error
Hi all,
sorry in advance, I am pretty new to Android TV stuff. I just bought a Beelink Mini MX3 II and was a little bit disappointed that it doesn't have true Android TV, so I'd really like to try this custom ROM.
I have some questions:
(1) Can I make a backup of the stock ROM before flashing with the Amlogic tool or do I have to find the stock ROM somewhere to go back?
(2) Maybe a stupid one, but: Can I try/boot the ROM directly from SD card just like the LibreElec builds?
(3) What exactly is the implication of the widevine issue? I read that Netflix isn't working, but what else is affected? I would especially be interested if Amazon Instant Video does work with this ROM?
Thanks!
There are currently 2064 users online. 0 members and 2064 guests.
