[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Did see that, but I don't see the v111 that is currently on my box there. But you already asked for it...
I found some other links here to mega.nz with latest v106M0 (MINIMXIII-II_106M0.img).
I guess this would be a start and then I could do an OTA update?
I thought I saw a thread with an overview and links to all official revisions, but I don't find it anymore.
Would a backup using TWRP work?
I guess I can't flash that with the Amlogic tool and you said something about repartitioning, so that sounds like no way to go?
Originally posted by Magendanz View PostThe lack of Widevine Level 1 certification is a problem that the stock OEM firmware will have too. Switching to a custom ROM won't fix the problem, but it won't make it worse either. If Netflix or Amazon Instant Video won't work on the custom ROM, they probably won't work on the stock OEM firmware. (Although, we've had some success running the tablet version of Netflix, if not the Android TV version...just not in HD.)
And yes, tablet version of Amazon Video is working, but as you said just SD (unfortunately).
Thanks!
Guest
Originally posted by steginger View PostWould a backup using TWRP work?
(The only problem with this is that TWRP backup doesn't include the bootloader partition, which could have changed. If you could go into Terminal in TWRP and add a "dd -if /dev/block/bootloader -of bootloader.img", that would make it more complete.)
Flashed the latest ROM without any issues on my Beelink Mini MXIII II (I'll provide the backups I made later on).
Looks really good - thanks!
For the record (or maybe someone has a hint for me):
I couldn't install Amazon Instant Video via Amazon Underground (not shown) like on stock ROM, so I installed 3.0.99.16701 via downloaded apk.
It starts OK, but it crashes some seconds after playback has been started (video and audio looks good before).
Another issue with this app is that you can't see a cursor (a grey box previously) anymore, so remote is pretty useless (scrolling works).
Both did work on stock ROM (with only SD of course), but I am not 100% sure if it was the same app version (did change these days) or if it is related to the new ROM.
I'll by chance try to test some older versions.
Guest
Originally posted by newkind View PostLooks like my wifi doesn't work on my new Mini M8S II and I can't finish setup wizard because of that
In theory, you could also boot to recovery after flashing the custom ROM to install the AMPAK update in TWRP, but I've experienced some issues doing that. At that point, the data and cache partitions haven't been formatted, and that seems to cause problems when you reboot after installing the update. I'm not exactly sure why.
Guest
Originally posted by XuanLee View PostI am using Android TV version. I want to change GG Play Store TV to GG Play Store Normal. How to do it? Thanks!!!
Originally posted by Magendanz View PostThe Play Store for Android TV is what should be installed on Android TV. If you want the normal store for tablets and phones, you should install the Nano or Stock variants of this custom ROM.
How do I use gg play on ATV ? Thanks!
Originally posted by steginger View PostFlashed the latest ROM without any issues on my Beelink Mini MXIII II (I'll provide the backups I made later on).
There are currently 2234 users online. 1 members and 2233 guests.
