Thanks a lot. Perfect work!
[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by gizmo862 View PostNow I just need the right TWRP.img-files for both boxes to make first of all a Nandroid-Backup of my existing Stock Roms before installing your custom roms. Which ones are the right ones to install?
Originally posted by Magendanz View PostFrom what I can tell, this VPN problem is just a generic issue with the app bar (a.k.a. action bar) running on Android TV. Several apps (including Settings and Terminal Emulator) are missing their toolbar icons on the right and the Up (<) button on the left isn't working.
Really nice work. A bit of an idea would be to use Sony TV to spoof the PlayStore. I had ago at editing the build.prop. I can make the device show up as the Sony TV, but I am still unable to download apps such as the iPlayer. I think I need to also add the framework files.
Anyway. This is the build.prop edits:
Code:# begin build properties # autogenerated by buildinfo.sh ro.build.id=MMB29V.S4 ro.build.display.id=SVP4KDTV15_UC-user 6.0.1 MMB29V.S4 3.709 release-keys ro.build.version.incremental=3.709 ro.build.version.sdk=23 ro.build.version.preview_sdk=0 ro.build.version.codename=REL ro.build.version.all_codenames=REL ro.build.version.release=6.0.1 ro.build.version.security_patch=2016-10-01 ro.build.version.base_os= ro.build.date=2016年 11月 21日 月曜日 18:03:22 JST ro.build.date.utc=1479719002 ro.build.type=user ro.build.user=root ro.build.host=BuildHost518 ro.build.tags=release-keys ro.build.flavor=Sakura_US-user ro.product.model=BRAVIA 4K 2015 ro.product.brand=Sony ro.product.name=SVP4KDTV15_UC ro.product.device=SVP-DTV15 ro.product.board=SVPDTV15 # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete, # use ro.product.cpu.abilist instead. ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.cpu.abilist=armeabi-v7a,armeabi ro.product.cpu.abilist32=armeabi-v7a,armeabi ro.product.cpu.abilist64= ro.product.manufacturer=Sony ro.product.locale=en-US ro.wifi.channels= ro.board.platform=mt5890 # ro.build.product is obsolete; use ro.product.device ro.build.product=SVPDTV15 # Do not try to parse description, fingerprint, or thumbprint ro.build.description=SVP4KDTV15_UC-user 6.0.1 MMB29V.S4 3.709 release-keys ro.build.fingerprint=Sony/SVP4KDTV15_UC/SVP-DTV15:6.0.1/MMB29V.S4/3.709:user/release-keys ro.build.characteristics=nosdcard,tv # end build properties # # from device/amlogic/q201_9377/system.prop # ro.adb.secure=1 # Set display related config ro.platform.has.mbxuimode=true ro.platform.has.realoutputmode=true #camera max to 1080p ro.camera.preview.MaxSize=1920x1088 ro.camera.preview.LimitedRate=1920x1080x30,1280x720x30,640x480x30,320x240x28 ro.camera.preview.UseMJPEG=1 ro.build.atv.version=1b #for bt auto connect ro.autoconnectbt.isneed=false ro.autoconnectbt.macprefix=00:CD:FF ro.autoconnectbt.btclass=50c #if wifi Only ro.radio.noril=false #if need pppoe ro.net.pppoe=true #the prop is used for enable or disable #DD+/DD force output when HDMI EDID is not supported #by default,the force output mode is enabled. #Note,please do not set the prop to true by default #only for netflix,just disable the feature.so set the prop to true ro.platform.disable.audiorawout=false #Dolby DD+ decoder option #this prop to for videoplayer display the DD+/DD icon when playback ro.platform.support.dolby=true #DTS decoder option #display dts icon when playback ro.platform.support.dts=true #DTS-HD support prop ro.platform.support.dtstrans=true ro.platform.support.dtsmulasset=true #DTS-HD prop end # Enable player buildin media.amplayer.seekkeyframe=true media.amsuperplayer.enable=true media.amplayer.enable-acodecs=ac3,eac3,rm,dts media.amplayer.enable=true media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER media.amsuperplayer.defplayer=PV_PLAYER media.amplayer.thumbnail=true media.amplayer.dsource4local=1 media.amplayer.startmode=true media.amplayer.dropwaitxms=100 media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm media.wfd.use-pcm-audio=false media.wfd.videoresolution-type=1 media.wfd.videoresolution-group=0 media.wfd.videoframerate=24 media.wfd.video-bitrate=2000000 media.html5videowin.enable=1 media.decoder.vfm.defmap=decoder ppmgr deinterlace amvideo media.decoder.vfm.drmmap=decoder amvideo #add for video boot, 1 means use video boot, others not . service.bootvideo=0 # Define drm for this device drm.service.enabled=1 #used forward seek for libplayer media.libplayer.seek.fwdsearch=1 #fix hls sync libplayer.livets.softdemux=1 libplayer.netts.recalcpts=1 #map volume ro.audio.mapvalue=0,0,0,0 #By default, primary storage is physical #ro.vold.primary_physical=true #Support storage visible to apps persist.fw.force_adoptable=true #add livhls,libcurl as default hls media.libplayer.curlenable=true media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod,bluray_mod #Hdmi In ro.sys.hdmiin.enable=true mbx.hdmiin.switchfull=false mbx.hdmiin.videolayer=false #adb service.adb.tcp.port=5555 #netflix ro.nrdp.modelgroup=S905 ro.vidon.platform=sunchip persist.sys.app.rotation=force_land ro.rk.systembar.voiceicon=true sys.status.hidebar_enable=true ro.platform.has.mcupoweroff=true #RC Settings ug_remotecfg.config=1 ug_remotecfg.switch=true #hardware monitor hw.savetime=true #gamepad settings misc.gamepad_settings=0 misc.gamepad_settings_device=0 ######## UBOOTENV VARIBLES - r/w as system properties ########## # # Now we can load ubootenv varibles to system properties. # We use a special prefix ("ubootenv.var" as default) to indicate that the 'property' # actually is an ubootenv varible. # # A ubootenv 'property' will be initialized during system booting. And when user set # a different value, it will be written back to ubootenv device immediately. # ## prefix of ubootenv varibles - should less than 16 chars. #UBOOTENV MTD NAME #ubootenv.var.bootcmd= #ubootenv.var.cpuclock= #ubootenv.var.gpuclock= #ubootenv.var.memsize= #ubootenv.var.ethaddr= #ubootenv.var.ipaddr= #ubootenv.var.gatewayip= ubootenv.var.outputmode= #ubootenv.var.screenratio= #ubootenv.var.oobeflag= ubootenv.var.480p_x= ubootenv.var.480p_y= ubootenv.var.480p_w= ubootenv.var.480p_h= ubootenv.var.480i_x= ubootenv.var.480i_y= ubootenv.var.480i_w= ubootenv.var.480i_h= ubootenv.var.576p_x= ubootenv.var.576p_y= ubootenv.var.576p_w= ubootenv.var.576p_h= ubootenv.var.576i_x= ubootenv.var.576i_y= ubootenv.var.576i_w= ubootenv.var.576i_h= ubootenv.var.720p_x= ubootenv.var.720p_y= ubootenv.var.720p_w= ubootenv.var.720p_h= ubootenv.var.1080p_x= ubootenv.var.1080p_y= ubootenv.var.1080p_w= ubootenv.var.1080p_h= ubootenv.var.1080i_x= ubootenv.var.1080i_y= ubootenv.var.1080i_w= ubootenv.var.1080i_h= ubootenv.var.4k2k24hz_x= ubootenv.var.4k2k24hz_y= ubootenv.var.4k2k24hz_w= ubootenv.var.4k2k24hz_h= ubootenv.var.4k2k25hz_x= ubootenv.var.4k2k25hz_y= ubootenv.var.4k2k25hz_w= ubootenv.var.4k2k25hz_h= ubootenv.var.4k2k30hz_x= ubootenv.var.4k2k30hz_y= ubootenv.var.4k2k30hz_w= ubootenv.var.4k2k30hz_h= ubootenv.var.4k2ksmpte_x= ubootenv.var.4k2ksmpte_y= ubootenv.var.4k2ksmpte_w= ubootenv.var.4k2ksmpte_h= ubootenv.var.digitaudiooutput= ubootenv.var.defaulttvfrequency= ubootenv.var.has.accelerometer= ubootenv.var.cecconfig= ubootenv.var.cvbsmode= ubootenv.var.hdmimode= ubootenv.var.is.bestmode= ubootenv.var.disp.fromleft= ubootenv.var.edid.crcvalue= # # ADDITIONAL_BUILD_PROPERTIES # ro.config.wallpaper=/system/etc/default_wallpaper.png persist.sys.media.avsync=true persist.sys.timezone=Europe/London ro.com.android.dateformat=dd-MM-yyyy ro.config.ringtone=Ring_Synth_04.ogg ro.config.notification_sound=pixiedust.ogg ro.carrier=unknown ro.config.alarm_alert=Alarm_Classic.ogg debug.hwui.render_dirty_regions=false ro.hwui.texture_cache_size=64.0f camera.disable_zsl_mode=1 rw.camera.usb.faceback=true ro.app.optimization=true ro.product.firmware=20170611 ro.product.otaupdateurl=http://10.28.11.53:8080/otaupdate/update ro.product.update.autocheck=false ro.vendor.sw.version=SCV2-ATV ro.hdmi.device_type=4 sys.display-size=3840x2160 dalvik.vm.heapstartsize=16m dalvik.vm.heapgrowthlimit=192m dalvik.vm.heapsize=512m dalvik.vm.heaptargetutilization=0.75 dalvik.vm.heapminfree=512k dalvik.vm.heapmaxfree=8m ro.com.google.clientidbase=android-sony-tv ro.setupwizard.mode=OPTIONAL ro.com.google.gmsversion=M_MR1_OCT_preview sys.fb.bits=32 persist.sys.hdmi.keep_awake=false wifi.interface=wlan0 config.disable_bluetooth=false poweroff.doubleclick=1 qcom.bluetooth.soc=rome_uart drm.service.enable=true ro.platform.has.pppoe=true ro.sf.lcd_density=240 persist.sys.dalvik.vm.lib.2=libart dalvik.vm.isa.arm.variant=cortex-a9 dalvik.vm.isa.arm.features=default dalvik.vm.lockprof.threshold=500 net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt ro.expect.recovery_id=0x35127ac9e0a580ad8935cd348bdb9f722b634f49000000000000000000000000
Guest
Originally posted by sweetnonso View PostHi Megendaz, sorry to be a pain, made any headway on this issue yet please?
Thanks to Magendanz for your ROMs !!!
A french friend has recently bought a T95N Mini M8S Pro S905X (m8spro) box at https://fr.aliexpress.com/item/New-T...670305568.html
This box uses 9082C Wif-Fi chipset
He first flashed COMPLETE ROM MINIMXIII-II_110M0_TVStock-20170319.img
and updated with update_MINIMXIII-II_112M0_TVStock-20170606.zip file.
At this step, Wi-Fi doesnt'work yet.
To fix 9082C Wif-Fi chipset :
-> Download WiFi-9082C.zip file -> https://mega.nz/#!pIFBiQqC!nxj48vPz6-5er7gM3XTGpCnWEF5evn1BLnK3DOlcKoM
-> Unzip files to put them on SD card or USB key
-> Copy these files on the box with root file manager (ie ES Explorer or X-plore File Manager) in folowing folders (Filenames are in bold) :
• /system/lib/9082xs.ko
• /system/lib/libhardware_legacy.so
• /System/bin/wpa_supplicant
• /System/bin/netd
-> Reboot the box to be able to activate Wi-Fi (His box works fine now)
/!\ Note: avoid to recover ancient files, prefer to rename them (ie: add "bak" our "sav" extestion); By this way, your can recover ancient files if this tips dosen't work
Note #2: You may give CHMOD 644 (Read-Write) premissions to folders and files before rename old files and copy teh new ones.Last edited by Stamp75; 19 June 2017, 18:39.
For anyone interested I have made some tweak packs that install via TWRP recovery. It adds a few features and fixes some of the bugs I was facing.
http://freaktab.com/forum/tv-player-...android-tv-rom
The goal of the tweak pack:- Brighten the screen so the details in the fur clothing is this music video are visible.
- Make this 4k 60FPS Youtube trailer run without stuttering (and to also be able to select 4K in the Youtube app).
Once all the tweak packs are installed and you let all the scripts in init.d run (can take up to 10mins) I can say I have achieved my goals (you may also have to wipe dalvik cache and cache partition so the installed apps get optimized).
With my tweaks added to this ROM, it runs butter smooth. I can even run PPSSPP with good frame rates.
EDIT#
Done a bit of fine tuning. It is as good as its going to be.
Some of my default apps I am using:- Gamesome Frontend or ARC Browser
- RetroArch (using these cores)
- PPSSPP
- ePSXe using libopenglplugin.so
- SMPC 17.1-Krypton
- Reboot Android TV
- Tv App Repo
- PuppetMaster.TV
- Aptoide
There are many more but this should be the main ones people will want.Last edited by pinguy; 06 July 2017, 06:05.
• /System/bin/netd
Can you please add those drivers to your next release?
Guest
Originally posted by Znida View PostCan you please add those drivers to your next release?
Originally posted by Magendanz View PostI could add the 9082C driver (.ko kernel module) and library (.so file), but the wpa_supplicant needs to replace the existing one...which I believe will disable wireless support for the other AMPAK chipsets. The better solution, I believe, is to put together an updater like I've already done for the Qualcomm QCA9377 chipset.
Originally posted by Znida View PostI can confirm that this is working! I have T95X 2G/8G and I had to edit the image to get this working, it crashed when I tried to copy files with ES Explorer. Now if I only can find the remote config file and some instructions to make it working.
-> Download the remote.conf file : https://mega.nz/#!wE0SiCTJ!-bWWEu6sU..._SpI-ipeCUSctg
-> Put it on SD card or USB key
-> Copy thise file on the box with root file manager (ie ES Explorer or X-plore File Manager) in folowing folders (Filename is in bold) :
• /system/etc/remote.conf
-> Reboot your box
Note #3: Trouble knowed with this box :
-> Use On/Off button to switch off your box
-> You may use 2 button to switch on your box (instead On/Off)
There are currently 2161 users online. 0 members and 2161 guests.
