[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Originally posted by Kamse View PostWhich version did you use because there's one but people say that it's laggy and kodi is bloated ?
I dont find it laggy, it works quite well. Except for the missing bluetooth and i just noticed my twrp recovery do not have a shell ;(
There is another 7.1.2 for the S905X TX3Mini-20170829, I just got it downloaded have not tried to burn it to a Box as of yet that is the next thing I will do.
Not for the S905X it is for the S905W my Bad.
#453.1Guest commented14 September 2017, 19:34Editing a commentYes, the direct link is here: https://mega.nz/#!l5wDFYZJ!4lInYROix...1kgSmeFdJA7GLc
There might be some good stuff to mine here, though. I'll investigate.
Originally posted by tht View PostThere is another 7.1.2 for the S905X TX3Mini-20170829, I just got it downloaded have not tried to burn it to a Box as of yet that is the next thing I will do.
http://www.tanix-box.com/downloads/
anybody know if these roms strip the stock atsc tuner support on 7.1 or how to enable it on a a95x 2/16 ?
i have tried several of these "asop" / tvstock ports but yet to find one that works for the android list of supported usb tuners (3 yeah small list heh)
currently on U2+p212_V0321_TVStock-20170730.img
looking to enable tuner support for avertv (H837)
love the work you guys are doing with these !!!!!
Originally posted by BP1 View Postany link with a step by step tutorial? i would like to try for the first time a custom rom on my mini mxiii ii. Thank you
i need the files in the first post and i can do it with Amlogic USB Burning Tool or Amlogic Burn Card. which one is the safest to not brick the device?
Originally posted by GliTch04 View Post
You can use either method but to use the USB burn tool you will need a usb to usb cable, and just match the device with the proper romLast edited by BP1; 18 September 2017, 18:06.
mini MXiii ii
downloaded from the first page from here https://1drv.ms/u/s!AoqocX31ecnXgZxJ-KG7heQQmD3tdA and used bootcardmaker 2.0.2. i insert SD cart in tv box and hold down the reset button on the box and then put inside cable. it doesnt start flashing. what am i doing wrong?Last edited by BP1; 19 September 2017, 18:49.
Originally posted by minixfreak View Posttheres an updated mini mx3 ii firmware .... maybe use it as base to update ?
this one? http://www.bee-link.com/Beelink-7284-1-1.html
did you " apply update from EXT " ?
i haven't updated using the sdcard method on these devices so i don't know the complete process ( i use the usb male to usb male and usb burn tool)
maybe somebody else would be kind enough to chime in here ?
but to me it appears you did something wrong on the sd card and the recovery could not find the update file to complete the task.
There are currently 1970 users online. 2 members and 1968 guests.
