https://forum.xda-developers.com/sho...83&postcount=3
[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Hi everyone,
To begining sorry for my bad English, i will try to explain my problem with great words
I had just installed the Custom Rom Android TV on my Mini M8S II S905X ( Thank you Guest for this great working) I used USB Burning Tool Method to flash my rom and install Android TV
everything work perfectly except Netflix who give me an particular which you know : Error ui-800-3
Is someone have a trust issue for this error except install Netflix Mobile APK ? Is a solution will be deployed ?
I have try everything :
Reboot internet
Unplug USB / No SDCard
Delete Netflix Cach system and data
uninstall reinstall
Install other version of Android Netflix : 4.0 / 3.5 / 3.2 / 4.2 / ...
Ty for your repost
Have a good day
Reboot internet
uninstall reinstall
Ty for your repost
Have a good day
Ok Question for whoever. im semi new, but i downloaded [update_MINIMXIII-II_112M0_Nano-20170606] so i have used the amlogic burn tool to flash other roms. The only thing is those roms were 1 .img to flash where as this one is 3 .imgs and then on top of that there is 2 dat files and the transfer list. this is a step up from what im used to lol. If you can help awesome!!!!
I'm still trying to get Bluetooth working on the Amlogic p212 boxes. The plan was to use the M8S Pro+ system image, but apparently there are precompiler directives that need to change and just adding the needed files won't do it. Without source, that's now a dead end.
My current effort is to adapt a S912 ROM for S905X, which requires downgrading Mali-T820MP3 to Mali-450MP. Still working on that.
Guest Correct me if am wrong, but can't you just develop the rom from an existing nougat stock rom? I saw one on this forum a while back.
Update: With the Z69 OEM firmware, hopefully we are one step closer to Nougat Android TV custom rom.Last edited by sweetnonso; 12 September 2017, 04:19.
The only OEM Nougat firmware on my radar for Amlogic p212 (S905X) is the U2+ and Khadas VIM. If you can find others, that would be fantastic.
Update: We just got the Z69 OEM firmware yesterday.Last edited by Guest; 10 September 2017, 21:03.
This ROM works great in a X9 android box (i think it is a clone of Mini M8S II). Eveything is ok (bt, wifi etc).
I have one question, i have a mi box remote (the one with the voice button) from a mi box that is now useless. I managed to pair it and everything works great except the voice button. Is there a way to make the voice button (and ofcourse the microphone of the remote) work with this ROM?
Been using this rom for some weeks since last post, and it has been perfect for daily use.
I installed TWRP for root access, and use DroidSSH for login access to the box, since ADB is not working.
I have made some modification to KODI, to at least support switching framerate and auto switch from HDR mode, when a HDR movie was played, so much easier with root to verify all this.
I tested the other roms which were compatible, but i had no remote control support and, there was some features corrupted when that rom was installed, since uboot was different too.
But so far, it works fine.
Im sorry, about my previous initial response that it was slow, that seemed to be a one time startup issue, where it halted the GUI too much, and i responded too soon on this, and wrote it was not using proper libraries, that is confirmed working fineSorry!
I will wait then for you to find the time to test the Xiaomi RemoteI can tell you that it works (press home + back button for pair), the problem is with the voice button. In Kodi using the keymapper app i saw that when i pressed the voice button to register it in an action the "61588" code (i think by memory) was registering and the button could be used so i guess that its a matter of mapping and the button will work (i just dont know how to do it in android) BUT that doesnt mean that the microphone will also work so easily. Thank you for your quick answer
Originally posted by sweetnonso View PostGuest Correct me if am wrong, but can't you just develop the rom from an existing nougat stock rom? I saw one on this forum a while back.
Remote is configured, wifi works, Netflix/Youtube runs 1080p (No UHD) and ADB is working as it should here.
I have not tested stability much or KODI and playback, but it is indeed very compatible, except Bluetooth do not start properly, log shows activity but im missing some things, hopefully Magendanz can do this better, as i also got the problem of repacking the 2GB image, removing all the "preinstall" 500MB and other things to lower the size.
Magendanz : If you need the remote.cfg / remote.tab files, ill post them for you.
There are currently 1870 users online. 1 members and 1869 guests.
