[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
    When using USB Burning Tool to install ROM I get following error, I am using the USB port next to the micro sdcard slot any idea what I need to do to fix?
    [08:54:37 582][Global][Inf]--Update HUB1-17
    [08:54:37 582][HUB1-17][Inf]--Update device path
    [08:54:37 582][Global][Inf]--Update HUB1-18
    [08:54:37 582][HUB1-18][Inf]--Update device path
    [08:54:37 613][HUB1-1][Inf]--Device is connected
    [08:54:37 613][HUB1-1][Inf]--Close device handle 0x000004c8
    [08:54:37 691][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&763bb00&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000004c8
    [08:54:37 753][HUB1-1][Inf]-------------Download DDR.USB-----------
    [08:54:37 753][HUB1-1][Inf]--2-0-0-0
    [08:54:37 753][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1
    [08:54:38 264][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x00005183
    [08:54:38 775][HUB1-1][Inf]--Write initial succeed
    [08:54:38 775][HUB1-1][Inf]--Upload encrypt at 0xc8100228
    [08:54:38 775][HUB1-1][Inf]--ulValue = 0xedfc318c
    [08:54:38 775][HUB1-1][Inf]--Read encrypt value succeed
    [08:54:38 786][HUB1-1][Inf]--Transfer complete
    [08:54:38 786][HUB1-1][Inf]--Run at address 0xd9000000
    [08:54:38 787][HUB1-1][Inf]--RunInRam succeed
    [08:54:38 790][HUB1-1][Inf]--2-0-0-0
    [08:54:38 790][HUB1-1][Inf]--CheckFileRunState succeed
    [08:54:38 790][HUB1-1][Inf]--runResult:0x 0,paraMagic:0x3412cdab
    [08:54:38 790][HUB1-1][Err]--ReadPara failed
    [08:54:38 806][HUB1-1][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
    [08:54:38 806][HUB1-1][Inf]--Close device handle 0x000004c8
    [08:55:05 580][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
    [08:55:05 580][Global][Inf]--Scan usb device
    [08:55:05 580][Global][Inf]--Aml scan WorldCup Device
    [08:55:05 580][Global][Inf]--Host: USB xHCI Compliant Host Controller
    [08:55:05 580][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9d2f&subsys_07041028& rev_21#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
    [08:55:05 580][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&369d7e28&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
    • Guest's Avatar
      Guest commented
      Editing a comment
      Looks like you're trying to flash it on an unsupported device.
    Magendanz,
    Thanks for response.
    I believe you are correct, stupid me, I took a closer look at my box and it looks like it is a Beelink Mini X3, not a Mini X3 2, with a build number MINI MXlll107L1, pic of the back markings below. Luckily the burn image software stopped me loading an incorrect image.
    Are you able to supply me with a link to best (in your opinion) ROM for the Mini MX3?
    As my Mini MX3 is already at Android 5.1.1 my preference would be for an Android 6 ROM.
    Thanks for the pointer, I will give it a go and respond in that thread
    Does that mean I cannot run Android 6.x on my Beelink Mini MXlll?
    • Guest's Avatar
      Guest commented
      Editing a comment
      Yes, you can only run Android 5.1.
    I didn't know that, thanks for letting me know, it has stopped me looking for the impossible Android 6.x ROM for my MX3
      Hello guys!
      First all thanks so much for all the hard work...I have several boxes on my family and everyone loves your custom roms. I currently have 2 Mini M8S II, 1 MX3 II and one X96 MINI (this one running the TX3 Mini rom).
      My question is...I'm trying to do fresh installs on all of them and I've managed to clone the first three using TWRP backup and restore with your rom without any hassles...Just had to reconfigure some small things. My problem is that I use team viewer to help my family with some troubleshoot whenever necessary and I install most of the apps from the website directly. After doing this cloning, all my boxes are stuck with same name, serial number and no way to change it...I've tried Xposed framework with several id changers but none of them stick..
      Is it possible to change it on some prop file? They all have the "0123456789abcdef" serial number and "Asus Nexus Player". I've managed to find some info on the build.prop but didn't touch it without knowing for sure what would happen! And also the serial number is nowhere to be found...Spend hours searching for it but no joy...
      Basically can someone tell me where I can change permanently the serial number?
      Thank you!
        This rom works great on Scishion v88 pro. The box was pretty much useless until this rom came out. I used amlogic usb burning tool. After the inital startup I got the box to work on 1,2mhz max and 100mhz min using no frills cpu in perfomance mode. Well, all hd channels now work in Kodi without any hiccups. Thank you so much for this fantastic rom. I didnt tried wireless, only wired connection.
          In your opinion, will this ROM work on Beelink MINI M8S PRO?
            esta rom funcionara con t95n mini m8s pro?
              Originally posted by konst55 View Post
              I see wireless chipset AP6212A.
              I repeat, on stock firmware sound quality is good.
              What in this case should I do with Bluetooth?
              Maybe you have a pill (as zip-flle to TWRP), that will cure problem Bluetooth?
              However, if the problem is not solved, I will still stay on this custom FW !
              I
              Hello Magendanz! I ask you to excuse me for the previous pasquillo on the topic of problems with sound on Bluetooth.
              It turned out that the _interference_ between Bluetooth and WiFi creates this problem.
              This is solved only by connecting TV Box with Ethernet.
              Changing channel numbers or bandwidth on the access point does not give an effect! Only Ethernet.
                Super ROM thanks.
                Any cure yet for Netflix to work with remote, normal scrolling etc? Sorry if it has been asked. thanks.
                  Por favor alguien me podria decir si esta rom funciona para la caja t95n m8s pro s905x
                    You need to test it, if this works you can share with us your experience.
                      Guest please what's difference between nano and stock variant
                      • Guest's Avatar
                        Guest commented
                        Editing a comment
                        Just the variant of OpenGApps that gets installed.
                      Lo pry funciona perfectamente lo unico que no funciona el control ir.
