but it looks like i have hard bricket my box when i picked ''apply update from EXT'', it doesnt turn on. no red and blue light.
[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
#467.1Guest commented25 September 2017, 06:15Editing a commentsuperceleron and I were just discussing that a few days ago. The thinking had always been that it was a Widevine L1 DRM issue, but the behavior's the same even on the M8S Pro+. It's possible that this is just a longstanding configuration issue that we've gotten wrong since my first ATV build, or it could be something more devious that Google is doing that only allows the feature to run on official Android TV boxes like the Nexus Player and NVIDIA Shield TV.
The truth is that we don't know, and I haven't had the time to pick through the logcats and examine the smali to determine how the code paths differ. It's time intensive work, and both of us have paying gigs right now as well as other custom ROM releases in the queue.
Dear Magendanz thank you for a great work with this ROM.
My Scishion V88 pro with stock firmware was a complete disaster, it was slow, laggy and almost unusable. Kodi was working but a video was stuttering.
Here is a small list of what's not working and what's working properly.
Scishion V88 pro 1GB RAM / 8GB RAM
- box light is wrong now, it's red when it's ON and blue when it's OFF (not a problem for me)
- remote doesn't work (also not important since I use air mouse, and stock remote is very bad)
- I can turn off the box, but can't turn it on with an air mouse remote. Had to take a cable out every time, that's a problem, any advice on how to fix this problem?
- RAM expander doesn't work, but I don't need it now, cause everything is working very smooth, and there is a default VMEM of 500MB
- KODI dark image problem, I saw that this is an AMlogic problem
- Google Music crashed once, but this didn't repeat
- WiFi is working great
- Google store works fine
- Youtube working great
I will do some testing and put the results here.
Thank you once again!
Guest if I got you right, with remote.conf my remote will work the same as air mouse works now? I still won't be able to power on the box? In that case I don't need remote and updated remote.conf.
Something strange happened this evening and now I can turn on and off the box with my air mouse remote. I didn't change anything, same box, same ROM ?!?!
I hope it will stay like this
Hello Magendanz, hello Freaktab,
I'm a user of your ROM for weeks. This is the best: thanks a lot.
I own a D4X16 box, thus I only had to replace some files (boot.partition, bootloader.partition, DDR.usb and UBOOT.usb) with those of the stock ROM using Amlogic Customization Tool : given my limited knowledge, it's in my opinion not supposed to change the behaviour of your ROM.
Originally posted by Magendanz View Post- Enabled multi-user support.
It ended up "working" with the smartphone procedure. But I still had "Settings stopped", so I question the reliability of what I did...
Maybe you could help me please... (I add, in case, that the box is not set in English).
Thanks a lot, and again thanks for your great ROM.
Regards,
This custom ROM wasn't tested on the X96, but sometimes you will get lucky. More often, you'll find the wireless chipsets or IR remotes are different, which may not be an issue for you if you're using Ethernet and an air mouse. You're basically on your own trying to modify it, but search the forum first. Others may have already done the work to adapt this for the X96.
Originally posted by zafeira View PostCan i use it also for X96 2/16?
1) Wifi is ok, did not test ethernet
2) I am not using the IR controller. I am using usb wireless keyboard instead which works well. Seems that USB ports are OK.
3) Youtube, google play store works well. Unfortunatelly there is almost nothing to install from the store for Android TV
4) USB BT dongle with broadcom chip inside did not work for me
Looks like X96 has the same Amlogic board inside, the DTB file for latests x96 firmware matches the one inside this custom firmware.
Guest first, let me say thanks for your great work.
I own X96 device and has burned your image into X96 successfully. Motivation was the support for external USB Bluetooth dongles you are claiming in the change log:
Changelog (20170606): Added kernel module for many USB Bluetooth dongles (btusb.ko).
Unfortunately, USB BT dongle (should be with broadcom chip on-board) does not work for me. I can turn on the BT but it turns off it self after the while.
X96 does not have built-in BT module. Might it be possible to resolve this somewhere in firmware config files to tell android to look for usb dongle instead of built-in BT?
Well not exactly Magendanz I am trying to merge features from your rom and xannytech's rom. So technically it is still your rom and I like your logo and anim. better- that should flatter you. In xannytech's rom animation is located in system/media, but in your rom it's not there. Logo should be somewhere in /logo_res folder but I don't know how to decompile those blank files without format. How am I supposed to learn when no one tells me or shows me? I have tried everything I am capable of ...I am not a software developer. ....Please. I thought that whole point of this forum is helping each other.Last edited by fluoir; 23 October 2017, 18:57.
Well, we do like to maintain some creative control of our builds. That said, there's quite a bit of the information you need already posted here: http://freaktab.com/forum/developmen...cks-by-finless
There are currently 4790 users online. 3 members and 4787 guests.
