[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Rom works great! It's very very stable! Thank you!I have found a bug in the latest update from 23d May - you can't jump from the input field to the on screen keyboard via remote. You have to use the 'cursor' mode. Besides that if someone would finally figure out the Netflix for Android TV solution - this rom would be 100% complete!
Originally posted by newkind View PostRom works great! It's very very stable! Thank you!
I found post this "Solution for Widevine level 3 DRM found for Dolamee D5 android 6.0.1"
->http://freaktab.com/forum/tv-player-...-android-6-0-1
Is it possible to adapt solution for this Firmware ROM ?
_____
Originally posted by newkind View PostRom works great! It's very very stable! Thank you!I have found a bug in the latest update from 23d May - you can't jump from the input field to the on screen keyboard via remote. You have to use the 'cursor' mode. Besides that if someone would finally figure out the Netflix for Android TV solution - this rom would be 100% complete!
Originally posted by Magendanz View PostSeems to work fine for me after I set a lock screen PIN or password. Which variant are you using? Nano, Stock or TVStock?
Guest
Originally posted by sweetnonso View PostI am using the TV Stock on mini m8s ii. When you click the VPN under network settings, it doesn't give you that '+' icon option needed to manually set up a VPN profile.
Originally posted by Magendanz View PostOkay, the problem seems to be specific to the TVStock (Android TV) variant, and it's also happening on the GT1/S92 TVStock ROM. I don't see an obvious cause, but I'm continuing to investigate.
Originally posted by f4tal View Post
Just did this and got a success message. Power cycled the box and now it won't even turn on when its plugged in. Just get the red LED. Going to try to recover it with USB burn tool now.now i can not go to recovery mode and flash rom even with USB burning tool, please help!
Guest
Originally posted by techboy_xxi View Postsame to menow i can not go to recovery mode and flash rom even with USB burning tool, please help!
Originally posted by Magendanz View PostJust a reminder that the first flash from the OEM firmware should always be the full burn package using the USB Burning Tool or BootcardMaker. It's necessary to ensure partitions are correctly sized and it has more strict device tree checks than the OTA updater. You'll also get TWRP, which gives you more flexibility for recovery, should something go wrong.
Guest
Changelog (20170606):- Enabled multi-user support.
- Added kernel module for many USB Bluetooth dongles (btusb.ko).
- Reverted to AOSP keyboard, since Gboard just doesn't have the necessary D-pad navigation support. Leanback keyboard is still also available.
- Switched from spoofing the Xiaomi Mi Box to the Nexus Player.
- Removed several libraries that are no longer required.
- Updated for latest Beelink firmware OTA update (112M0) and Open GApps build (20170606).
On the bright side, this means that the ROM will work AS IS on the Mini M8S II, which uses the AMPAK AP6255.
There are currently 2266 users online. 1 members and 2265 guests.
