[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by Magendanz View PostChangelog (20170606):- Enabled multi-user support.
- Added kernel module for many USB Bluetooth dongles (btusb.ko).
- Reverted to AOSP keyboard, since Gboard just doesn't have the necessary D-pad navigation support. Leanback keyboard is still also available.
- Switched from spoofing the Xiaomi Mi Box to the Nexus Player.
- Removed several libraries that are no longer required.
- Updated for latest Beelink firmware OTA update (112M0) and Open GApps build (20170606).
On the bright side, this means that the ROM will work AS IS on the Mini M8S II, which uses the AMPAK AP6255.
Hello and thank you ! You are a killerthis firmware is on top
Guest
Originally posted by EagleEyeXZ View PostMagendanz do you also start with android 7.1.1 sdk? SuperCeleron said he does not have time now to start with it but what i read nougat can have a lot new features for the s905x chipset like HD audio
Surprisingly, I've gotten the farthest on the Z28, which uses a Rockchip RK3328. That chipset, however, has problems in that it seems to be natively running in 720p vs. 1080p.
Guest
Originally posted by sweetnonso View PostStill waiting for the VPN fix please.
Originally posted by Magendanz View PostFrom what I can tell, this VPN problem is just a generic issue with the app bar (a.k.a. action bar) running on Android TV. Several apps (including Settings and Terminal Emulator) are missing their toolbar icons on the right and the Up (<) button on the left isn't working.
Thanks a lot Magendanz !!!!
____
Box: Mini M8S II S905x
Location; France
Guest
Hello Magendanz!
I need a little help...
I own a Beelink GT1 and a Beelink Mini MXIII-II, both with QCA9377-chipset.
Now I just need the right TWRP.img-files for both boxes to make first of all a Nandroid-Backup of my existing Stock Roms before installing your custom roms. Which ones are the right ones to install?
Thank you in advance!
There are currently 2512 users online. 0 members and 2512 guests.
