[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by rajawaqas View Post
Guest
Okay, Live Channels is now updated to latest version...and the Google Play Store problem wasn't at all what I thought. Apparently, Google added a "feature" in v1.09.419 that hides the Live Channels app in the launcher if there are no channel sources available. This is a horrible UI design, which makes discoverability near impossible, but that's reality for now. What's really odd is that in v1.10.596 they even started ignoring the movie trailer channel provided in Google Movies & TV for Android 6.0 and later. When you upgraded from v1.09.419 the app would just DISAPPEAR from the launcher and the Google Play Store. Really, Google?!
Anyway, the workaround is to install another channel source like Haystack TV, Pluto TV, Bloomberg TV or the Weather Network TV. Once you do that, the Live Channels app will magically reappear.
Originally posted by Magendanz View PostYou mean the Mini M8S II, right? (There's a separate thread for the Mini M8S, which is based on the Amlogic S905.)
That means there's something in the AMPAK updater that's messing with SystemUI.apk. I have a Mini M8S II here, so let me see if I can reproduce the bug.
Which thread should I be following?
Guest
Originally posted by blue42 View PostI thought mine was s905x. in my cpu-z device tab it reads "MINI MXIII-II (p212)" but on the box it reads 'Mini M8S" Which thread should I be following?
That said, I was unable to reproduce your System UI crash. I confirmed that there's nothing in the AMPAK updater that touches SystemUI.apk, so it seems unlikely that the update did any damage.
Can you explain to me the steps needed to reproduce the bug?
Originally posted by Magendanz View PostYeah, when they updated the internals, AZW apparently decided it wasn't worth updating the label on the enclosure. You've got an Mini M8S II.
When I flashed should I have "force erase all" in usb burning tool instead of just normal erase? Wondering if something lingering from old install?
Guest
Originally posted by blue42 View PostWhen I flashed should I have "force erase all" in usb burning tool instead of just normal erase? Wondering if something lingering from old install?
Guest
Originally posted by Fenderman View PostWould it be possible to add a reboot option? Maybe in the context menu? I have a multinot setup with LibreElec and AndroidTV and would like to switch between the two.Last edited by Guest; 21 March 2017, 01:38.
Guest
Originally posted by blue42 View PostLooks like the micro sd card I had inserted (forgot it was there) had a file system error- needed a format. It was causing the issue with System UI.
I use the application and it's perfect for me
I am a total noob when it comes to android and tv boxes. I have the M8S version 2 ( https://www.gearbest.com/tv-box-mini...69.html?wid=21 ).
I use my tv box mostly for Kodi in addition to a few apps to stream stuff. Can I update with the UPDATE&BACKUP utility program to get this? I don't care if my data is lost. I don't have a SD card. Can I just download the update with the browser on the box itself? Do I have to do anything else? Is it something that doesn't work? Wifi etc??
Thank you so much
There are currently 2429 users online. 1 members and 2428 guests.
