[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
Guest
Originally posted by kabise View Post
Guest
Originally posted by minixfreak View PostWill this build work better then prahjister build for t5x pro
Originally posted by Magendanz View PostRainer Trunk is actually putting together an app that will include all the most popular remote.conf files, along with some photos. The idea is that on a rooted machine you can just pick your remote by appearance, and the app will install the correct file in your custom ROM.
Guest
Well, you should already be able to cast to the box from the Chrome browser...at least I can. However, I can't cast from Android apps or screen cast yet, and we're trying to understand the problem. Chromecast compatibility has been a longstanding challenge, and so it's likely that it could take a while...or we could perhaps even never crack the problem. Sorry, I wish I had a better answer for you.
Many thanks for this ROM!! I've been dying to find a stable+smooth android tv build (and still have a fully functional recovery/reset button). this one answers my craving.
On my Mini M8S Pro (s905x, 2gb ram, 8gb rom, mali-450 gpu, 10/100 lan) all the ESSENTIALS are working:
Wifi
USB
Original IR remote works
Rooted, clean, not-so-bulky install
AV-Port Reset Button working and able to dual-boot into LE 8.0 from the microSD, and the android OS hanging out internally.
I mainly use my box for Kodi running LE, but this android build caught my attention to work on the Android side of things.
Thanks again!
Hi there i tested playback and audio in kodi 17 and spmc latest.... playback in spmc is perfect and iec passtrough works for ac3 and dts no hd audio. Raw passtrough does not work... playback in kodi 17 using Android mediacodec is awful realy shuttering passtrough audio is.not working i think it is raw. I stay using libreelec for now.. keep up the great work
Guest
If an SD card is inserted, you can go to Storage & USB, click on the SD card, hit SETTINGS in the upper-right corner of the browse pop-up window, and you should have both Format and Format as Internal listed there. Unfortunately, this works on my S912 ROMs but not this one for the S905X. Going back to the original Mini M8S II OEM firmware, they seem to have disabled this feature and I inherited that change. I'm considering starting over with the Beelink MX3 II firmware to see if I can work around this problem, but I don't have the device to test with.
Originally posted by Magendanz View PostIf an SD card is inserted, you can go to Storage & USB, click on the SD card, hit SETTINGS in the upper-right corner of the browse pop-up window, and you should have both Format and Format as Internal listed there. Unfortunately, this works on my S912 ROMs but not this one for the S905X. Going back to the original Mini M8S II OEM firmware, they seem to have disabled this feature and I inherited that change. I'm considering starting over with the Beelink MX3 II firmware to see if I can work around this problem, but I don't have the device to test with.
(I could also test you releases based on the Beelink MX3 II)
There are currently 2828 users online. 1 members and 2827 guests.
