[ROM] Beelink Mini MX3 II / M8S II TVStock Nexus ROM (Android TV)
#497.1Guest commented28 November 2017, 23:17Editing a commentOneDrive links are being flaky lately. When in doubt, try the archive site here: http://freaktab.org/3~f
I have a small problem and I'm not sure if it's fault of SPMC or the rom. When I try to configure one of the addons in SPMC to store files on the MicroSD card I get an error message that SPMC doesn't have rights to save and store files on the SD card. Any one had this issue before?
Thanks Magendanz for this great rom.
Only problem I'm having is theres no add button in the vpn settings. Is there anything i can do?
Well, yes there now is. We've had this longstanding Action Bar bug on Android TV, but we just figured it out a couple of weeks ago. It requires a change to a setting in framework-res.apk.
Unpack: apktool d -s framekwork.res.apk
Delete: res\values-television-v8\bools.xml
Repack: apktool b -c framework.res
I'll incorporate this into the next release, but Marshmallow builds are a pretty low priority these days.
Guest I see several people say your Rom works fine on Nexbox A95X .. I am on Xannytech's 6.0 Rom and it allows me to boot to recovery (since the Nexbox reset is unreliable) but if I try to flash the image via TWRP it says either flash to boot or recovery and if I use boot (?!) it says insufficient partition space... Any advice please?
Guest Q: Is it possible to make this rom pass Google's new SafetyNet Test? I'd like to see if I can install Pokemon Go which uses SafetyNet and use it to scan the local gyms that I can see from my house... No spoofing honest ;-)
Originally posted by Methanoid View PostGuest I see several people say your Rom works fine on Nexbox A95X .. I am on Xannytech's 6.0 Rom and it allows me to boot to recovery (since the Nexbox reset is unreliable) but if I try to flash the image via TWRP it says either flash to boot or recovery and if I use boot (?!) it says insufficient partition space... Any advice please?
Any ideas?
Guest
Try hitting the Start button in USB Burning Tool, boot the box normally, insert the cable into the USB OTG port, and then issue the following command from a terminal window:
Code:reboot update
We use this as a workaround on devices that don't have a reset switch and yet still have bootloaders that require the reset switch to be pressed on USB insertion to be detected. It's not terribly well documented.
Originally posted by Magendanz View PostTry hitting the Start button in USB Burning Tool, boot the box normally, insert the cable into the USB OTG port, and then issue the following command from a terminal window:
Code:reboot update
Well, the source is here: https://github.com/adt1-dev/android_...13.0/AppDrawer
Or, you can just copy it from my ROMs and place in /system/app.
There are currently 2935 users online. 0 members and 2935 guests.
