[LibreELEC] Bolt Ons! AceStream & EmulationStation + RetroArch/Libretro for S905/S905X devices!
Originally posted by scottmu64 View Post
Thanks but still nothing, I'm wondering if it's to do with JoKeRz 32 bit libs addon, kszaq said it possible needs recompiled with the updated libs from the s805 builds
It may be worth trying to grab the emulationstation & retroarch bin from the AlexELEC-S805 /usr/bin folder to see if they will work.
Originally posted by pinguy View Post
AlexELEC has separate builds for S905/S805/S812.
Was that all what was needed? To replace the emulationstation & retroarch bin with the ones from the S805 build?
It's bizarre as I've copied over lib files etc previously but never worked.
pinguy AlexELEC-arm-2.2.5 updates:
the new version of «EmulationStation», «RetroArch». Updated most emulators
Waiting for your updates. Thanks in advance.
Update. Added a huge amount of new cores. Not all of them tested but the few I tried worked fine (see first post for all cores).
Updated and removed any libs that are not in use (if you are going to install this update over an already installed version, remove the lib folder from emulator.tools.32bitlibs first).
Same instructions to install.
PS. a Nintendo DS core has been added. Its a bit laggy but I think with some setting up it could run OK (also the default theme for it has no logos. The other themes are fine)Last edited by pinguy; 13 June 2017, 06:14.
With the latest update you will need to delete the emulator.tools.32bitlibs add-on before installing/extracting the NEW package.
There are currently 1848 users online. 0 members and 1848 guests.
