[LibreELEC] Bolt Ons! AceStream & EmulationStation + RetroArch/Libretro for S905/S905X devices!
Originally posted by pinguy View Postniabi cool you have the hatari_libretro core. Going to have to test that. The Atari ST was my first computer.
Originally posted by niabi View Post
there are other cores not enabled for the S905 that I want to try, but not sure if they will work, I will keep you posted.
Tested hatari_libretro core. Its a no go. Doesn't work. Bit of a pain in the ass to setup. But even after setting everything up and pointing the config to the correct bios. It still doesn't work. shame
Right now I'm trying to get a hold of all this...I use Kszaq's LibreElec build and your bolt-ons.
If I understand correctly, this here: https://forum.libreelec.tv/thread-4785.html
is another approach to yours. He takes Kszaq's LibreElec as base, adds Retro gaming and packs it to a new LibreElec derivate...which one can update with new Kszaq LibreElec versions.
AlexElec is a whole other custom LibreElec build of what I understood and pinguy only takes the retroarch/libretro part from this build.
From niabi's LibreElec build only Emulation Station (which is the frontend?) and missing retroarch/libretro part.
Am I right?...Reason I'm writing this is I am trying to decide which way I will go considering Retro Gaming (I know Retroplayer is comming in the future but I cant wait)
What other differences are there between niabi's retroarch/libretro part and yours?
The thought of having niabi's LibreElec build and possibility to update with a new version from Kszaq and after maybe take a newer niabi update and vice versa also sounds good.
Or do you try to pick the best of all?! In this case I guess I'll stay with your bolt ons and try to update them..
Originally posted by trohn_javolta View PostRight now I'm trying to get a hold of all this...I use Kszaq's LibreElec build and your bolt-ons.
In addition to what you know, I am always trying to get other non-libretro-emulators working, for example I have PPSSPP standalone working, which in my tests gives me an increase in FPS in some games, and I also have Advancemame, which makes MAME games look beautiful (but the performance is not as great as mame2003 or FBA), I almost have the amiga emulator (UAE4ARM ) running, I just need to figure out how to configure it. But there is no reason why pinguy can't add those later if he likes to.
The idea behind my build is to eventually turn it more into an emulation machine (Like Retropie) than a Kodi machine.
But all in all it seems the right choice for you is pinguy 's addonLast edited by niabi; 10 March 2017, 18:07.
Thanks for the insight! I guess I'll stay with these bolt ons...only if I could get my controllers to work...
Maybe someone can help: I have two 8bitdo SFC30 NES Controllers. Initially I somehow connected one via bluetooth to libreelec to try it out. It worked, I think also in games... Later I unpaired it again and now if I pair them I can only get the dpad to work in kodi. In emulation station I can configure them right, everything works. Until I'm in a game, the controls are messed up..Like only 3 buttons work: start seems to be A button, Y button seems to be right dpad and B button is up...
I tried to pair with kodi in different modes, starting controller with start button is joystick mode. Kodi shows a gamepad. Start+B is bluetooth keyboard mode, cant pair it this way...and so on.
Now I updated the firmware of the controllers to 2.70 and copied right .cfg file from pinguys link to right directory, rebooted but still it doesn't work. Any ideas?
Originally posted by trohn_javolta View PostThanks for the insight! I guess I'll stay with these bolt ons...only if I could get my controllers to work...
Ok, initially I was on 8.0.0c, now I'm on 8.0.0e. Just tried it again and turns out connecting the controller, pairing, choosing it in bt settings and hit "refresh" there manually, resolves it. Now I can controll and setup kodi and emulation station like I want, but the issue persists ingameX is right dpad and A is up dpad...rest gives no response..
Originally posted by trohn_javolta View PostOk, initially I was on 8.0.0c, now I'm on 8.0.0e. Just tried it again and turns out connecting the controller, pairing, choosing it in bt settings and hit "refresh" there manually, resolves it. Now I can controll and setup kodi and emulation station like I want, but the issue persists ingameX is right dpad and A is up dpad...rest gives no response..
Originally posted by trohn_javolta View PostCopied the content of the folder into autoconfig folder but didnt help. If i start a snes game in the beginning it shows the controllername in yellow so i guess it's recognized...
There are currently 1793 users online. 3 members and 1790 guests.
