edit: it seems it will not work "it is designed for Windows and Linux 86x architecture"
[LibreELEC] Bolt Ons! AceStream & EmulationStation + RetroArch/Libretro for S905/S905X devices!
You have done exactly what I'm looking for but... It doesn't work for me with LibreELEC 8.0 from kszaq on S905X.
I enable the addons (32 libs, RetroArch and EmulationStation) but when I launch ES it reboots to kodi.
Do you know if it's working with LE 8?
EDIT: I tried with 7.0.3.012 on same device and it works. Both of my tests were conducted on fresh installs.Last edited by *Frisk*; 22 February 2017, 19:19.
If you don't mind could you test this on LibreELEC 8.0 and tell me what it says:
Code:cd /storage/.emulationstation/ ./emulationsatation
Originally posted by niabi View PostOk I fixed emulationstation for LE 8I will upload a binary soon
EDIT#
And Done :P
New update for EmulationStation + RetroArch/Libretro. Changed the core for N64. It now uses parallel_n64 instead of glupen64.
Binary's for EmulationStation & RetroArch have also been updated.
EDIT#
Nope. Still not working on LibreELEC 8.0. Will wait for your updates.Last edited by pinguy; 23 February 2017, 01:54.
how so? I tested it with a few games with no problems.
what version are you using?
Also how did you fix the "png_init_filter_functions_neon" issue? I grabbed the latest binaries from your build including libfreeimage-3.17.0.so. Same issue. EmulationStation won't start.
Originally posted by pinguy View Post
What version of LibreELEC are you running?
i was actually running a version of libreelec 8 that came with kodi 17 from this forum thread ..
.., although I now see that the full version 8 has officially been released.
i might try flashing back to version 7 though if you say emulation station works better with that. most of the skins i prefer for kodi probably won't be updated for Krypton anyway so it's the best of both worlds
My PS1 games are in bin format without the cue file. What happens is when I click the game to play, pcsx_rearmed opens but the disc doesn't get detected.
Attached is a recompiled libfreeimage which was causing the prblem, try it and let me know if it worksAttached Files
There are currently 2651 users online. 0 members and 2651 guests.
