[ROM] Mini M8S II/ Mini MX3 II and Others SCV1A-ATV (Android TV)
Hello All, do you know if the rom is working on M8S - II (It's not the mini!) ?
=> This one : https://www.gearbest.com/tv-box-mini-pc/pp_555824.html
Thank you
Originally posted by poub09 View PostHello All, do you know if the rom is working on M8S - II (It's not the mini!) ?
Thank you
I want understand I thing about this ROM. Can I change ROOT/UNROOT state by some menu? In this case the UNROOT state pass SafityNet test?
I need use a app on my M8S ii but this app doen't start on ROOT device so I think to use this rom but only if I can change ROOT/UNROOT by ROM and if it pass SafityNet test.
Originally posted by array81 View PostI want understand I thing about this ROM. Can I change ROOT/UNROOT state by some menu? In this case the UNROOT state pass SafityNet test?
No it wont pass SafetyNet, this rom is a bit old now when i made it the SafetyNet was not so problematic as it is now
Is it possible set ROOT/UNROOT by menu to try to trick the apps? I don't know if this app check only root or also SafetyNet.
I have installed this rom.
It works but I have a 2 small problems.
FIRST PROBLEM
I extended internal memory with a 16GB SD card. I have configured this SD as internal to use it with app however when I try to install big games (like Alphalt Extreme) I get an error about the lack of memory space. I checked the memory information on settings and it confirme me about 18GB of free internal memory (3GB real internal memory and 15GB of extension).
It seems that the memory extension is not considered.
Before I had installed the "official" rom v115 and I could install this app without any problem.
SECONDO PROBLEM
The app TV App Repo doesn't work. After set app I get an message error.
Hi Superceleron, firstly thanks for your efforts to date.
Regarding the rom, i have flashed using usb tool, all went well.
My box is an MXQ Pro 4K (S905X, Mali, 2GB/16GB)
Everything works that I need for the most part. I mainly use plex, youtube and netflix.
My issue is as follows:
The device runs very slow, Eventually i figured why it was running slow, this firware only seems to run the cpu frequency at a max of around 1500mhz and total ram only shows around 840 total available with 640 used).
The Disk also showed 11GB if im not mistaken (not too worried about that as most of it free anyway)
I can confirm that both in the stock rom which was android 6 and in librelec kodi my ram was around 1980MB and the frequency was just under 2000mhz
Is there a way I can manually adjust the memory and frequency in a file somewhere to correct?
Thanks for any help.
There are currently 3917 users online. 3 members and 3914 guests.
