[ROM] Mini M8S II/ Mini MX3 II and Others SCV1A-ATV (Android TV)
I have tried to install this rom via sdcard and it has locked my box, I tried to recover it by passing the rom through USB_Burning_Tool however it crashes in the 2% I tried several roms and all lock in the 2% however I found an MXQPRO-v8 that loaded successfully however Wifi and the go remote do not work can help me to load this rom successfully?
My Mini M8S II Box
Originally posted by summersbr View PostI have tried to install this rom via sdcard and it has locked my box, I tried to recover it by passing the rom through USB_Burning_Tool however it crashes in the 2% I tried several roms and all lock in the 2% however I found an MXQPRO-v8 that loaded successfully however Wifi and the go remote do not work can help me to load this rom successfully?
My Mini M8S II Box
1° IR original config file
- Try to download "remote.conf" file (3 Kb) at https://mega.nz/#!dJt3SByI!zOgRvZObZ...YYQ_S9zRegoj7A
- Copy this file to /system/etc/ folder (change permissions to Chmod 644 -> read/write)
2° Patch Wi-Fi Chipset
- Try to download "update_S905X_AMPAK-20170313.zip" file (40.5 Mb) at https://mega.nz/#!kcsEnLYT!cyeeAzQur...I9opwB_qWMDl_0
- Flash this file with TWRP
Originally posted by Scantrexx View PostJust some questions...
With Mini M8S II will I be able to use netflix (android tv) with some ROM ? which box/dongle could I be able to use it ? and what is Widevine L1 ?
You need to buy a mi box or nvidia shield
Or use Netflix for phone with a mouse
Widevine L1 is the drm ( L1 = level 1 etc... )
Originally posted by billouetaudrey View Post
And what abaout Roku ? Does Neflix ATV runs on it ?
thanks
Originally posted by Pereirinha View PostHello,
I use that rom and now my box don't turn on, I used the burning software and a micro sd, my box is mini m8sii someone can help me??
thanks a lot. I'm shacking
Hi, try this rom
Originally posted by Pereirinha View Postsorry if I don't explain well, I used the microsd method: I put the micro sd in the slot and after that I press Reset and put the alimentation cable on the box at the same time. and on the tv show the android icon saying upgrading and after that the box turn off and no more turn on.
There are currently 1323 users online. 1 members and 1322 guests.
