[ROM] Mini M8S II/ Mini MX3 II and Others SCV1A-ATV (Android TV)
Originally posted by XuanLee View Postsuperceleron new updated on 28/04? Where is changelog? thank
superceleron May you include the following commit in kernel? https://github.com/osmc/vero3-linux/...7c404f03cdd1d3
Originally posted by johngalt View PostNetflix TV won't work, and the tablet app variant will only work for SD without Widevine L1 (which your device won't have).
But thks for the heads up on that commit
I will try, since the changes are really large!
The difference between 666 and 742mhz is just enough to get rid of stutters in very high bitrate 4k hdr scenes from my testing. To clarify, the 792mhz in commit message is for 905, 742 is for s905x.
If you have issues with it or decide not to, would you be willing to release the source code to the kernel you used so I may give it a try?
Thank you superceleron ! There's one other commit I forgot about that I meant to link: https://github.com/kszaq/linux-amlog...3d6ebd0f67b6f2
Yes i will rls the kernel.
Originally posted by Dandroid534 View PostWhat usb dongle would work with live channels?
That dont need to be in the kernel, and well its not in the kernel its on the dtb, i already do it (internal build's) on the s912 to 792mhz, also internal builds s912 full 8 cores at 1.5Ghz.
Well it should work all that work on android.. but i never tried since i dont have one!
Thank you
EDIT: Ignore the above. I tested more, and it would seem that all 23.976fps media in spmc has a stutter every ~1:20. Awhile back there was a commit floating around to fix the 23.976hz clock. Has this been merged? I'm running spmc with "always" set for display refresh rate switching.
EDIT2: I fixed the stutter by disabling refresh rate change in spmc, and enabling "hdmi self-adaptation" in android playback settings.Last edited by johngalt; 09 May 2017, 17:43.
Hello,
First I am a french noob without a good english, so please keep cool !
After, I tried this ROM on my Zenoplige T95x (Sunvell T95x, isn't it ?) but my box is brick. I reinstated a recovery but I really want to enjoy the Android TV experience. Can you help me.
Thank's a lot for your help and I am so sorry for the mistakes !
I'm looking to get some functionality I had in LibreELEC, so have two questions:
1) Has anyone figured out audio passthrough hiccups every few minutes? It occurs on RAW or IEC in SPMC or FTMC, on both DTS and AC3. This did not occur at all in LibreELEC. I suspect this could be related to the bad fractional refresh timing since it doesn't happen as much on integer framerate sources, but don't have any data to back it up.
2) Are there any AOSP patches floating around for AFTV-like resolution switching? I'd be interested in checking them out and seeing if I can modify this system to support similar.
There are currently 6244 users online. 1 members and 6243 guests.
