2º not that i know!
[ROM] Mini M8S II/ Mini MX3 II and Others SCV1A-ATV (Android TV)
Made sure output was set to HDMI in settings, and IEC was set in SPMC for passthrough
Installed the apk and enabled storage permission. No way to set "notification priority" in the Android TV variant, so ignored that step.
Opened and selected "Reboot." This did nothing, so I manually rebooted.
There was no sound on boot as the instructions noted, so I opened the app, left it open while going back to spmc, and tried watching a movie. I still got the hiccups.
Is the disconnect between the steps I found and the results because this is an Android TV variant?
Edit: looks like I need to be rooted for it to work.Last edited by johngalt; 13 May 2017, 11:30.
I want to ask 2 things
1) Is this rom suitable for Beelink Mini MXIII II?
2) If the above question is yes, does it solve this problem? When I use a paired ps3 controller and enable it as a game pad using the Sixaxis Controller app, the controller works fine, but the d-pad up opens the file browser, R3 button opens the web browser and L3 opens up music app. Is there any other solution fixing this?
Yes you need to enable root in the setting of my rom!Last edited by johngalt; 14 May 2017, 02:49.
1. I cannot update installed app and cannot install any app.
it displays 'prepare to installation... never installed.
How can I install any app or update pre installed one?
2. I want to use Google cast(chrome cast) when I want to watch YouTube from my phone to the TV.
Often, I want to share my phone's screen with Miracast.
Is therethere any way that I can use these ?
Originally posted by EagleEyeXZ View PostYou can use frequency switcher addon works perfectly for kodi/ftmc
Edit superceleron it looks like I jumped the gun about that fixing passthrough clipping. I've done the "reboot' from that app about five times and on boot still get clipping with raw 5.1 ac3 output. Any suggestions? I'm only using android for HDR/10 bit output support, so even if you can recommend another firmware to try I'll give it a shot.Last edited by johngalt; 14 May 2017, 23:05.
Hay superceleron I'm kinda new to Android, and still learning my way around, but I brought a Mini m8ii and flashed your Rom.
It's so much better than the stock Rom !
Just wanted to personally thank you for this, and other projects you have helped me in the past !!
Sent from my HTC One M9 using Tapatalk
Originally posted by Invisable View PostHay superceleron I'm kinda new to Android, and still learning my way around, but I brought a Mini m8ii and flashed your Rom.
Originally posted by pel.hu View PostI've read the whole topic but I cannot find answer fro my questions.
Is this rom can play HD audio on HDMI passthrough?
The 4k youtube play is very tempting but if I cannot watch my movies with DTS HD MA or TrueHD then I'll stay on LibreElec..
superceleron Thank you for the awesome ROM. I am using this on a Beelink Mini MXIII ii and everything is working fine except updating/installing app through Google Play Store. Installation through Aptoide works fine but Play Store is stuck on "Install Pending" for updates to existing apps as well as new installs.
I have tried to clear cache/data for Play Services and Store and have also removed and re-added google account but the issue remains. Any ideas would be most welcome.
Another issue I have found is that activating voice search from the Home screen does not work. It works for searching within apps.
There are currently 2841 users online. 1 members and 2840 guests.
