[ROM] Mini M8S II/ Mini MX3 II and Others SCV1A-ATV (Android TV)
Ok guys... i totally forgot this... to disable led when sleep on my kernel you guys need to go to "settings->Display->DayDream" and change "Power key action" to Hibernation and there you go led off and yes Hibernation is some type of sleep that is even better than sleep, it wakes fast as sleep.... Got it?!? LOL
Attach it here
The only thing i see yesterday is that the POWER ON doesnt work.
Maybe there is a litte fix for the power on.
Originally posted by matayuma View PostThis rom works for NEXBOX A95X (2/8) .
You only need to copy the remote.conf from the original firmware.
Tested.
P.D. Superceleron, if you will include te remote.conf for nexbox, i can send you.
regards.
Is it better or same ?
Originally posted by ssarava9 View Post
Hows the speed and running compared to Xanny ROM ?
Originally posted by minixfreak View Postthe 9377 update does indeed work great job
Originally posted by minixfreak View Postim working on the bootloader situation for a95x .... when i add the new bootloader i get a wierd boot image then it doesnt boot ..... testing a few different bootloaders see if i can fix the issue ... superceleron doing a good job time to give him a breaki and lets others help him out
you need to try it... Xanny rom is normal android, this is Android TV...
Ok nice adding it to the 1ยบ post and changing the topic name.
watch out on the bootloader test... you may brick the device and then you need to short the pins LOL
Please advise where i can download youtube apk for 4k videos, the one in playstore only max quality 1080p, your rom has youtube 4k app and badly need it.
Appreciate your help on this
There are currently 2623 users online. 0 members and 2623 guests.
