[ROM] Mini M8S II/ Mini MX3 II and Others SCV1A-ATV (Android TV)
Originally posted by minixfreak View PostSorry superceleron I had a death in the family ... so haven't tried ... I will be back home tonight and let you know
My condolences!
Originally posted by dovento View PostSuperceleron, I installed the LightHome launcher and the box does not work well, your rom is not compatible with the launcher? Or is it problem with apk installation? Thank you
I'm curious how this runs on my box compared to Magendanz build. I like the ATV variant, and so far it's running smooth.
I like that Xposed is installed in this one, but the OP says DEFAULT UNROOTED. I will be testing this build, regardless ... just wondering what the major differences were.
I have one quick Question or more to the Point a Request if it can be done.
I install this Rom on my KM8 2gb / 16gb 905X box it seems top work for the most part and is Fast as far as booting goes my only Problem is the wifi the KM8 uses the BCM4335 chip also it seems that the same chip set is used for Bluetooth, So the Request is to add the wifi Drivers that would help a lot Bluetooth I don't use that much.
And if it can't be done that is fine I have a X96 905X Box coming maybe next week I think it will work with it.
Great Work as always
Originally posted by Central View PostWorks in 1g/8g ..... exploring
thanks superceleron
Originally posted by xfade View PostI'm curious how this runs on my box compared to Magendanz build. I like the ATV variant, and so far it's running smooth.
Originally posted by tht View PostI have one quick Question or more to the Point a Request if it can be done.
There are currently 1874 users online. 0 members and 1874 guests.
