(Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6)
stable . superfast . clean . leanback . android TV (ATV)
This custom mod is based on the UGOOS UT4firmware and Shomari OC/T8C techniques
[ Supported other devices ]Trosmart Rk3368 Meta | Zidoo X6 Pro | ...
Now with support for different hardware (kernel) of other boxes with WiFi Chips:
- AP6330 (like CSA90 RK3368 box)
- RTL8723bs(like Andoer Z4L box)
Google android TV ROM with the following features:
- TURBO BOOST 1600 (all 8 cores @ 1600 Mhz - click for more details)
- 3D FPS BOOSTER (Switch UI resolition on the fly to a lower resolution to get more FPS in 3D games
Recommended setting = 1280 720 190 - (need root)) - Voice Search support (use a USB mic)
- Fully IR remote support (Settings key = voice search)
- App Drawer (for easy start of side loaded non ATV apps)
- International Leanback Keyboard (long press OK for special characters)
- Google Voice input as Keyboard (use a USB mic)
- Easy edit for Gampad settings (2 different apps)
- APP2SD (more space to install your apps & games)
- USB Switch (USB Host / USB OTG)
- Network file server (for easy APPs sideload)
- Firefly Wireless Assistent (check ugoos,net/remote to get the app for your mobile)
- Opera ATV Internet Browser
- 2 App Stores (Google ATV & Aptoide TV)
- DLNA & AirPlay Server
- Set your custom NTP Time Server (ntp.org)
- easy ROOT / UN-ROOT (#SuperSU)
- TWRP 3.10 - Custom Recovery
- AC3/DD/DTS audio pass thru
- Masked HDMI
- HDMI Color Mode (no more wrong colors on older TVs)
- Autoframerate
- Custom Keylayout files for the following devices
- Z4 IR Remote
- Rii mini i8 wirless Keyboard
- mini Keyboard witch Touch-pad (TeckNet X331, iPazzPort KP-810, Topop 2.4Ghz, VicTsing 2.4Ghz)
- Apple Wireless Keybord
- Xiaoji Gamesir-G3f - etc ...
Known Issues:
- NON
some screen shots
Google ATV leanback home screen (launcher) with "App Drawer" for a easy start of side loaded non ATV apps
Display settings
Advanced Ugoos Settings (ROOT, Fileserver, Gamepad Settings, Wireless Assistant, Masked HDMI)
USB Switch: Host or OTG (to connect to PC and transfer files)
IR Remote friendly Leanback keyboard, Google voice typing, Virtual Remote Keyboard
Leanback Keyboard Hint: Use long press on OK to get special characters of your language like üöäéèźúß etc...
Voice Search function (use a USB mic)
Hint: Use settings button (between the 4 volume buttons) on IR Remote to start.
Easy Gamepad Test & Setup (already 2 apps included
This one is Gamepad Settings
And this one is Gamepad Tester (@ App Drawer)
Get more internal storage with APP2SD to install your apps & games (only possible in case the app supports this feature)
APP2SD hint: To move the main part to an external SD card, go to: Settings > More Settings > Apps > (select any app) and check if MOVE TO SD CARD is activated.
At the screen shot above you can see that 106 MB out of 132 MB is moved to the external SD card.
how to install
change log
V2.5 BRE (Busta Rhymes Edition)
- Added TURBO BOOST 1600 Modus for all 8 CPU Cores (THX to Shomari for the inspiration on good OC/T8C techniques)
- Added 3D FPS BOOSTER (on the fly UI resolution changer)
- Updated Kodi to Krypton V7.1 (can now show the RK3368 CPU temperature)
- Updated TWRP to V3.10
- Updated ES File Explorer to the latest version
- Updated all Google Apps (Date:020518), except Play Service
- Replaced stock Browser with Google Chrome
- Changed Opera start page to google.com
- Fixed TWRP can't mount System partition
- Fixed a serious Ugoos ROOT uninstaller bug that breaks the filesystem
- Added support for Trosmart Rk3368 Meta IR Remote and several others I can't remember
- Enhanced UI smoothness
- Enhanced eMMC, SD & USB r/w speed
- Enhanced RAM r/w speed
- Enhanced Network (WiFi/LAN) speed
- Enhanced Media streaming (Audio/Video) smoothness
- Yeah OK, I enhanced the overall system performance Dramatically
- Fixed several other small issues I can*t remember ...
V2.0 FSE (Fatboy Slim Edition)
- Fixed App2SD
- Replaced buggy yablrar Kernel with the latest stock Kernel
- Fixed issue with side loaded apps (not enough space)
- Fixed Standby (previous only screen off. Now real standby. USB power stays on.
So you are still able to wakeup your device with any USB emote controller/keyboard) - Fixed Power LED (now red in standby & power off)
- Added App Drawer (for easy start of side loaded non ATV apps)
- Updated all Google Apps (Date:170418)
- Replaced few buggy apps against comparable ATV apps
- Removed buggy Google Cast service
- Replaced Google picoTTS vs TTS for better voice output quality
- Updated SuperSU to the latest version
- Added TWRP custom recovery
- Enhanced load time of several system apps
- A lot small other fixes & System, Kernel enhancements
V1.0
- Inital port from UGOOS UT4 V.1.4 TV firmware for Z4 RK3368
download
Note: The needed USB driver, the Flash Tool and the installation guide are included to the ROM download file.
[ V.2.5 BRE - Busta Rhymes Edition ]
[ V2.0 FSE - Fatboy Slim Edition | link 2 ]
[ V1.0 ]
additional infos
- Check this post on how to back & restore your data while updating to a new version of my rom.
- Check this post in case you have audio/video out of sync issue with Kodi
- Check this post to show the real RK3368 CPU temperature within Kodi
- Check this post in case you like the the features, speed etc. of my ROM, but you don't like android TV (ATV)
- Old Ugoos Kodi 16.1 fork, based on RKMC with Rockchip patches (download)
[ Note ]
To enable Daydream (screensaver, auto sleep & shutdown)
Enable Developer options: System > Device > About >> ( click 7x on 'Build' )
Diasable Stay awake: System > Prefernces > Developer options > General > Stay awake >> ( Off )
Free Daydream ATV app tipp: Photo Gallery and Screensaver
(Photo Sources: Facebook, Flickr, ,Google Photos, Local photos on your device, ,NASA Photo a Day, 500px)
