[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
Originally posted by axionflow View PostThis rom same problem with the original. Apk MyVister, no rewing or fast foward, video. Aplication working fine in mibox xiomi, and other rom for rk3368. Check this aplicacation, https://www.myvidster.com/app/android_update. Error wrong , video error
Other Android app can handle these web videos much much better.
Install MX Player via Playstore.
Then change your MyViste settings to Legacy Player.
On the first start of a video you will see the following option on how to open the video. Select >> MX Player (Always)
BTW I recommend to use Kodi, to watch someone else is having fun in heaven like Fatboy Slim.
Search for "Kodi Whitecream Repository" to see Angels in HD & "Kodi VideoDevil Add-on" for SD.
Originally posted by minixfreak View Postwill ap6330 wifi work now ?
What's your box brand/model? Is it the Andoer Z4L?
This is the full list if all wifi/bt drivers included to my rom.
Code:Ampak AP6181 Ampak AP6210 Ampak AP6212 Ampak AP6234 Ampak AP62x2 Ampak AP6330 Ampak AP6335 Ampak AP6354 Ampak AP6441 Ampak AP6476 Ampak AP6493 Ampak GB86302I AzureWave AW-NB108 Broadcom B23 Broadcom BCM4330 MediaTek RT2870AP MediaTek RT2870STA Realtek RK901 Realtek RK903 Realtek RTL8723A Realtek RTL8723BS Realtek RTL8723BU Realtek RTL8723B Top Victory Electronics ARS WL211
My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
Originally posted by minixfreak View PostI can load it but wifi doesn't work
Must be flashed over my V2.0 FSE ROM (It's only a kernel & resource file)
Instruction pic inside of the download.
Let me know if it works or not.
Much luckLast edited by cOOLio; 17 April 2017, 23:08.My contributions to the community
Hot news you have to check out at Shomari True OctaCore thread. (see link below)
Closed beta test will start soon. So slots are still available.
In case you want to join the closed beta test phase, please leave a comment why you are interested and what you can test, to make this release final.UPDATED - Version 2.0 - March Update http://i.imgur.com/zfWDp7b.jpg AnTuTu Benchmark 6.3.3 This is/was a personal project (I **really* dislikeLast edited by cOOLio; 15 April 2017, 11:29.My contributions to the community
Originally posted by axionflow View PostThe steps you propose do not work with any player.
Try to give Fast foward and the video stops working. As I said before, the application has been treated in various devices and versions.
And this HTML5 Videos will be played by the old Stock HTML Browser. I just added to the ROM for a bit more backward compabilitty for non ATV apps. So it is not my main focus. Maybe it is better to find comparebale ATV apps. And I also mention already some similar add-ons for Kodi. And who knows, maybe you will find also a MyVister add-on for Kodi. But this you have to find out on yourself.
And last but not least, yut you can try to fix this on your own.
Just get the needed files from one of the device where it is working and replace them.
These files must been replaced with the version from the other boxes. You can do this with ES File Explorer and its root features.
Go first to: System > Apps > (select the app) > deaktivate botah of them.
Then you can reaplace them on the fly.
Code:/system/Browser/[B]Browser.apk[/B] /system/HTMLViewer/[B]HTMLViever.apk[/B]
Android System WebView >> V39 eng.serega-arm (HTMLViewer.apk)
Browser >> Version 5.1.1-eng_serega.29161027.154156 (Browser.apk)
And in case you fixed it an your own, feel free to share the new files you added. So I could add them to my next ROM version.
Remote control >> Please send me a link to the stock firmware of your device. Then I will see what I can make.
But one important thing. I will only make a new remote resource fix, if you promise to give feedback, if it is working or not.
I will gladly give you feedback. I have worked with other ionix programmers, fellow. Onix, I was there giving you feedback .. I remember one of my requests was to see if you could include L1 or L3. Thanks to wasser, he helped ionix with L3. Nowadays almost all the boxes have L3, including Ugoos.
I was in a principle contributing to fellow.
Ionix has made a kernel and resource, which works with almost all custom firmware. The last one I did, I disabled sd, and recently using an old kernel and resoource, I was able to activate sd.
If you understand that your kernel and resource have the same similarity, then there is nothing to do and continue to use ionix kernel and resource.
About my vidster, I will continue experimenting and will tell you later if there is any change. This application and the behavior of this, could be other bug hidden within the firmware.
Your firmware has no warming up problems.
Thank
Traductor de Google
http://www.mediafire.com/download/76...1_20160617.rar, Link to the stock firmware of my device Tronsmart R3368 Meta. This firmware haved many proplem.
Tronsmart discontinuous support.
There are currently 2234 users online. 2 members and 2232 guests.
