Shomari tried to use a full time boost, while he disabled all temperature checks of the CPU. So his T8C technique is definitely faster than mine, but in my test it was also not stable at all. Becasue it crashes all the time, within seconds, when I made stress CPU test with 100% CPU load. That's why I tried somthing else, more stable, but also a bit slower then Shomari T8C.
[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
And my TURBO BOOST 1600 technique is comparable with the Turbo Boost Intel use for its Core i5 & Core i7 CPUs. So you can't use the boost all the time. Only that long until the CPU reach its critical temperature. Then the boost will turned automatically off, to normal speed, to protect the CPU from overheating. So this boost speed up all normal conditions a lot, but not in longterm runs with maximum CPU load of 100%. In those conditions the CPU has the same speed as without my TURBO BOOST 1600.
Shomari tried to use a full time boost, while he disabled all temperature checks of the CPU. So his T8C technique is definitely faster than mine, but in my test it was also not stable at all. Becasue it crashes all the time, within seconds, when I made stress CPU test with 100% CPU load. That's why I tried somthing else, more stable, but also a bit slower then Shomari T8C.My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
And Shomari had always, at least, 4k more in AnTuTu when we both use the same ROM. My theory to this different results is, it depends always on the cooling capebilitys of your CPU cooler. Mine seems to be one of the bad ones. Maybe the passive cooler was bad clued to the CPU during production process?My contributions to the community
My Z4 is a Andoer Z4 and the CPU temperature in idle is mostly already at 60 °C.
Check with my Kodi 7.x temperature fix.
Originally posted by jit18 View PostWell, what can i say...
Pictures speak for them selfMy contributions to the community
Originally posted by jit18 View PostNow i am curious, send me a link of the Z4 Rom that has only 26K antutu score on your box...
I will try this out..My contributions to the community
And what kind of cooler (size) do you use right now? Because there is no much space inside of the box.
Because of this heat collecting metal plate. Or did you remove the silver metal plate?
Originally posted by cOOLio View Post
Maybe because I have xt-z4-v12 (20160222) version.
And antutu in stock rom was 36000 too so no improvements and maybe atv seems slower than stock launcher.
I'm using antutu 6.3.3 and antutu 3d 6.1
I used a chipset cooler from an old Motherboard (Elitegroup).
You must remove the screw above the cooler on the heat collecting metal plate.
It needs a little testing with the hight of the cooler, its very important to have a good contact with the metal plate (i used a thermal paste).
Originally posted by koes View Post
yuntab z4 is a little bit different. No foresee emc and no samsung ram. Mine have samsung KLMAG4FE4B-B002 emc and hynix H5TC4G63AFR ram.
These are my results for the accurate test with reboot. The default test ends for me always in a cache (RAM) hit. So the result of the default test without a reboot is always wrong.
Internal memory (eMMC)
Read 85.33MB/s - Write 19.25 MB/s
RAM
RAM copy 2832.40 MB/s
To activate a comparable test you must long press on "Internal memory" then select "Accurate - with reboot"
Then start part 1 of the test (write), reboot the box and start a1 SD bench again to start part 2 (read).
No, i didn't heat up the cooler.. May be it's easier then, i don't know, just try it out... Worst case you buy another box
It needs a little testing with the hight of the cooler, its very important to have a good contact with the metal plate (i used a thermal paste).My contributions to the community
There are currently 1854 users online. 0 members and 1854 guests.
