Can i flash this rom on my device?
[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
Originally posted by cOOLio View PostRK3368 Kernel & Kernel Resource Files for my V2.5 BRE ROM
To support more RK3368 hardware like WiFi/BT, LAN chips and IR Remote Control
Flash resource & kernel files with AndroidTool v2.3x or TWRP Recovery (already included to my V2.5 BRE ROM)
IMPORTANT: You always have 1st to flash my full ROM, than just update/flash the resource or kernel files.
(resource)
All resource files are with the same TURBO BOOST 1600 speed setting.(?) = until now no test report availableKRS Resource Image File Supported[WiFi/BT] Supported Devices KRS_1.2.9a_AP6330_resource.img AP6330 CSA90 (?), ... please test an report KRS_1.2.9b_AP6335_resource.img AP6335 Z4 RK3368, Trosmart Rk3368 Meta, Zidoo x6 pro, Ugoos ut4 (?), ... please test an report KRS_1.2.9c_RTL8723bs_resource.img RTL8723bs Z4L (?), ... please test an report
Additional Note: KRS 1.2.9b is the same as KRS 1.2.8 that is already included to my V2.5 BRE ROM.
KRS 1.2.9b has onlyone change. It supports 2 more IR Remote from devices other than the Z4.
So there is no need to flash this version to your Z4. Its only to support more IR Remote Control of other boxes.
(kernel)
The following RK3368 3.10.0 Kernel are all tested with my ROM V2.5 BRE on my Z4.
Rom Starts and the have all nearly the same speed with my ROM V2.5 BRE.
Kernels with AP63xx & RTL8xxx support several WiFi/BT chips.Kernel file Z4_AP63xx_RTL8xxx_kernel.img is already included to my V2.5 BRE ROMKernel Image File Kernel Info Z4_AP63xx_RTL8xxx_kernel.img qiachy #22 - 30.03.2016 CSA90_AP63xx_RTL8xxx_kernel.img yangfeihu #60 - 12.09.2015 Z4L_AP63xx_RTL8xxx_kernel.img yangfeihu #28 - 21.11.2015 ugoos_ut4_kernel.img serega #15 - 13.10.2016 zidoo_x6pro_kernel.img xiaoweihua #12 - 17.02.2016
Feel free to mix up those files, to get the best hardware support for your device.
Z4 = Z4_AP63xx_RTL8xxx_kernel.img & KRS_1.2.9b_AP6335_resource.img
Test example for a RK3368 box with AP6330- Flash only KRS_1.2.9a_AP6330_resource.img
- Flash KRS_1.2.9a_AP6330_resource.img & CSA90_AP63xx_RTL8xxx_kernel.img
- Flash KRS_1.2.9a_AP6330_resource.img & Z4L_AP63xx_RTL8xxx_kernel.img
Test example for a RK3368 box with RTL8723bs- Flash only KRS_1.2.9c_RTL8723bs_resource.img
- Flash KRS_1.2.9c_RTL8723bs_resource.img & CSA90_AP63xx_RTL8xxx_kernel.img
- Flash KRS_1.2.9c_RTL8723bs_resource.img & Z4L_AP63xx_RTL8xxx_kernel.img
IR Remote Control Keylayout files
In case some or all keys of your IR Remote Controller doesn't work, you should check the following!
To enable the stock keybord layout file for your IR Remote Control, just copy the file "ff680030_pwm.kl" (see download) of your box to the folder "/system/usr/keylayout/" and overright the existing one. Reboot the box and enjoy the new keylayout file setting.
Important:- Do not forget to chmod 0660 the file "ff680030_pwm.kl"
- Or use ES File Explorer (RootExplorer) to do so: Mark file (long press) >> More >> Properties >> Permissons [Change]
and set it to >> rw- r- r- = (Read: Owner, Group, Other | Write: Owner)
Check also this thread to redefine any Keyboard, Gamepad, Remote Control to your own needs.
Best Practice Example
Box/Device Files to use tested & confirmed Z4 RK3368 box Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img YES Zidoo X6 Pro Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
Zidoo keybord layout file (ff680030_pwm.kl)YES Trosmart Rk3368 Meta Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
Tronsmart keybord layout file (ff680030_pwm.kl)YES Ugoos UT4 Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
Ugoos keybord layout file (ff680030_pwm.kl)not yet Z4L RK3368 Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
KRS_1.2.9c_RTL8723bs_resource.imgnot yet
Please be so kind and post your test result, even if it is not working!
This will help all others, not me. Thanks
KRS Resource, Kernel & Keylayout: Download
@minixfreak
Thats the best I could give to support your RK3368 AP6330 box. Now it is up to you to test. Much luck!
And please give feedback.
@dincis1
I found some time to finish up some things I was already working on.
To solve your Mele F10 Pro remote. audio issue please flash KRS_1.2.9b_AP6335_resource.img & ugoos_ut4_kernel.img
Ive tested it with my Skype USB headset. Works perfect to me. Except the stock IR Remote. But you mentioned it already.
Much fun
Originally posted by Vega78 View PostHello everybody. 10x for your greater firmware for TVboxes !!!
please help me with problem after flashing my Tronsmart R68G to "Android TV" 5Ghz wifi cant see, please take advise what i doing wrong ?
Try a lower channel on your router you set manually, maybe you have some luck.
Tronsmart closed their tv box business months ago, hope it isn't one you bought recently.
Originally posted by gefattern View PostHi ,
any chance to see this Rom with MM , Ugoos released , everbody knows a MM for RK3368 ,
will be interesting .
greetings / gefattern
The Ugoos MM ROM has a problem with Youtube stuttering and also after a while device becomes slower, 30-35k Antutu score while it should be 45k+ score if working normally.
There are currently 1963 users online. 0 members and 1963 guests.
