[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
Sorry for my english...
I installed your firmware on the TV box Zidoo X6 Pro. It's really nice and well done but I have problems in my tvbox.
A) About 10 minutes after starting, the TV box will start to reboot itself in a loop. Probably I think the problem is the temperature. can I do something to solve?
B)I installed the only operating system without patches, modifications or firmware specifically for Zidoo X6 and yet everything seems to work. Have you created a package that already includes everything or is there something that does not work without those patches?
cOOLio
Help me please...
I can not install the patches:
with the twrp tells me to choose in which position I want to install the patch but I do not know what to choose;
with the AndroidTool Or RKBatchTool I do not know how to do, can someone give me instructions? thank you
The main problem is that I do not have the partition addresses on AndroidToolHelpLast edited by Denethor; 07 September 2018, 17:51.
Originally posted by cOOLio View Post
Exactly, with the help of AndroidTool v2.3x your are able to erase also the whole flash, before you flash any full image file.
Originally posted by januxool View PostOn the Ugoos website, download the firmware to your liking and install kernel.img and resource.img according to your needs.
in my case, install Uggos UT4 firmware, system.img (cOOlio), kernel.img (wasser 3368), resource.img (Tronsmart r68), in a Beelink i68 and work perfectly with streaming DRM.
Originally posted by BEN001 View Postshopping release Android 7.1 for Z4
http://4pda.ru/pages/go/?u=https%3A%...tml&e=76137985
wow! can you post your firmware?
Originally posted by mag190 View PostHello, I'm sorry for my weak English. Thank you for a great job and Rom. I would like to ask how to install Lucky Patcher all the time I'm popping up the application has not been installed. My equipment is Octa core ekb 367 Z4. Thank you and I am asking you for an answer.
do you have root ??? , not really a good App ,
greetings / gefattern
Originally posted by nashpantheron View PostHye and good day to all, I want to ask, will this ROM can safely install on Scishion V88 Star 16GB+2GB RAM version TV Box (V99 Star, AP6255 WiFi chip, Rockchip RK3368) ? Thanks for any kind input. Really loves to try out this awesome ROM as I am a big fan of ATV ROM.
you can try , but for sure no Wifi , not sure if this Drivers
are supported in this Rom , good luck , gefattern
Hi ,
Hello again in advance thank you for answering. The firmware has root and the Lucky patcher I use on samsung and according to me it is not a bad application. So I understand that you can not install this application on this rom? But if there is the possibility, please ask for instructions on how to do it.
There are currently 2718 users online. 3 members and 2715 guests.
