http://4pda.ru/forum/index.php?showt...ost&p=58677199
[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
Originally posted by BEN001 View Post
Hi BEN001 the files you have linked are unavailable to download ( in particular parameters.txt and the AP6330 resource) can you please share them?
Originally posted by BEN001link AP6330 resource, parameter txt in the firmware
https://drive.google.com/file/d/0By2...ew?usp=sharing
Inviato dal mio MI 5s Plus utilizzando Tapatalk
HI All,
I have successfully installed the ROM on my Z4 Android TV box. And I am happy. Though I have a few queries as follows:
1. I am able to mirror my iPhone screen on the Z4 box using Air Play but I am unable to mirror my Android phone screen on it using Cast. Do we not have this Casting feature in this ROM (BRE 2.5)? And DO we also not have Google Cast feature in this ROM?
2. I have a laptop HP Envy with Windows 10. I has an app Connect with the help of which I can mirror my Android phone screen (Mi Redmi Note 4) on the Laptop. Z4 original ROM was also able to find my Laptop as Wireless Display but it could not mirror the screen in it and the mirroring attempt used to end in an error. However, this ROM is unable to even find the laptop as wireless display
3. The above 2 can be ignored, but this one is very important. YouTube videos are not playing correctly. I could clearly see that the videos are not playing smoothly. Is there any settings that I am missing. Please help
Regards,
Khurram
Thanks Coolio,
The only problem is that it has no output pcm by spdif
In my VicTsing i68
* KRS_1.2.9a_AP6330_resource.img (AP6330 seen inside)
* Z4L_AP63xx_RTL8xxx_kernel.img (I have tried and it seems the most stable)
* Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img Tronsmart keybord layout file (ff680030_pwm.kl)
And the kodi https://github.com/JamesLinEngineer/RKMC works perfect, not like the default one
cOOLio, I installed this on an Zidoo X6 and love it. Thank you!
I do have a couple of questions:
1. When I hold the power button down on my remote, I get a power menu. The reboot works but the power off doesn't. It powers off and turns right back on. It's not that keys aren't mapped right, they are. Everything works. However, when I press and hold the power button, I get the options to Power off, reboot, sleep, or reboot bootloader.
The power off turns box off but it turns right back on.
The reboot works perfectly.
The sleep does work but the LED stays blue (instead of red)
Any way to fix this? Especially the power off?
2. I've been trying to get Magisk on the box and for some reason I can't after flashing your ROM, do you have any advice on this?Last edited by bigpoppapaul; 28 August 2017, 22:36.
There are currently 3668 users online. 1 members and 3667 guests.
