[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
    Originally posted by cOOLio View Post
    Now to the real fun of it …
    Are you kidding me?
    >>> READ
    What? You reboot to recovery? With my ROM? How did you do that? Long press of the power button and select reboot to BOOT LOADER? That's not recovery. That's BOOT LOADER to flash a rom with the PC. To start TWRP >>> READ
    It‘s always a bad idea to put the cart before the horse. My suggestion. Start from the beginning. 1St READ carefully, then flash. Much success ...
    sorry if you think that they are stupid questions, but everyone is not as clever as you.
    I've read this from the first day you post and I wanted to test it but I was a little afraid as I've never done it before.
    Finally, I download the apks from apkmirror in the pc (opera browser in z4 crashes when I go to apkmirror) and I install them on the tv box. Try twice and bad results as you see in the pictures (the first time 31000 and the second only 26000).
    I've use that app manager but it is a pain, you know the one I was referring to.
    Sorry for my mistake about the recovery.
    The flash process ended ok, so I don't know what to do more
      RK3368 Kernel & Kernel Resource Files for my V2.5 BRE ROM
      To support more RK3368 hardware like WiFi/BT, LAN chips and IR Remote Control
      Flash resource & kernel files with AndroidTool v2.3x or TWRP Recovery (already included to my V2.5 BRE ROM)
      IMPORTANT: You always have 1st to flash my full ROM, than just update/flash the resource or kernel files.
      (resource)
      All resource files are with the same TURBO BOOST 1600 speed setting.
      KRS Resource Image File Supported[WiFi/BT] Supported Devices
      KRS_1.2.9a_AP6330_resource.img AP6330 CSA90 (?), ... please test an report
      KRS_1.2.9b_AP6335_resource.img AP6335 Z4 RK3368, Trosmart Rk3368 Meta, Zidoo x6 pro, Ugoos ut4 (?), ... please test an report
      KRS_1.2.9c_RTL8723bs_resource.img RTL8723bs Z4L (?), ... please test an report
      (?) = until now no test report available
      Additional Note: KRS 1.2.9b is the same as KRS 1.2.8 that is already included to my V2.5 BRE ROM.
      KRS 1.2.9b has onlyone change. It supports 2 more IR Remote from devices other than the Z4.
      So there is no need to flash this version to your Z4. Its only to support more IR Remote Control of other boxes.
      (kernel)
      The following RK3368 3.10.0 Kernel are all tested with my ROM V2.5 BRE on my Z4.
      Rom Starts and the have all nearly the same speed with my ROM V2.5 BRE.
      Kernels with AP63xx & RTL8xxx support several WiFi/BT chips.
      Kernel Image File Kernel Info
      Z4_AP63xx_RTL8xxx_kernel.img qiachy #22 - 30.03.2016
      CSA90_AP63xx_RTL8xxx_kernel.img yangfeihu #60 - 12.09.2015
      Z4L_AP63xx_RTL8xxx_kernel.img yangfeihu #28 - 21.11.2015
      ugoos_ut4_kernel.img serega #15 - 13.10.2016
      zidoo_x6pro_kernel.img xiaoweihua #12 - 17.02.2016
      Kernel file Z4_AP63xx_RTL8xxx_kernel.img is already included to my V2.5 BRE ROM
      Feel free to mix up those files, to get the best hardware support for your device.
      Z4 = Z4_AP63xx_RTL8xxx_kernel.img & KRS_1.2.9b_AP6335_resource.img
      Test example for a RK3368 box with AP6330
      1. Flash only KRS_1.2.9a_AP6330_resource.img
      2. Flash KRS_1.2.9a_AP6330_resource.img & CSA90_AP63xx_RTL8xxx_kernel.img
      3. Flash KRS_1.2.9a_AP6330_resource.img & Z4L_AP63xx_RTL8xxx_kernel.img
      Test example for a RK3368 box with RTL8723bs
      1. Flash only KRS_1.2.9c_RTL8723bs_resource.img
      2. Flash KRS_1.2.9c_RTL8723bs_resource.img & CSA90_AP63xx_RTL8xxx_kernel.img
      3. Flash KRS_1.2.9c_RTL8723bs_resource.img & Z4L_AP63xx_RTL8xxx_kernel.img
      IR Remote Control Keylayout files
      In case some or all keys of your IR Remote Controller doesn't work, you should check the following!
      To enable the stock keybord layout file for your IR Remote Control, just copy the file "ff680030_pwm.kl" (see download) of your box to the folder "/system/usr/keylayout/" and overright the existing one. Reboot the box and enjoy the new keylayout file setting.
      Important:
      • Do not forget to chmod 0660 the file "ff680030_pwm.kl"
      • Or use ES File Explorer (RootExplorer) to do so: Mark file (long press) >> More >> Properties >> Permissons [Change]
        and set it to >> rw- r- r- = (Read: Owner, Group, Other | Write: Owner)
      Check also this thread to redefine any Keyboard, Gamepad, Remote Control to your own needs.
      Best Practice Example
      Box/Device Files to use tested & confirmed
      Z4 RK3368 box Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img YES
      Zidoo X6 Pro Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
      Zidoo keybord layout file (ff680030_pwm.kl)
      YES
      Trosmart Rk3368 Meta Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
      Tronsmart keybord layout file (ff680030_pwm.kl)
      YES
      Ugoos UT4 Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
      Ugoos keybord layout file (ff680030_pwm.kl)
      not yet
      Z4L RK3368 Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img
      not yet
      Please be so kind and post your test result, even if it is not working!
      This will help all others, not me. Thanks
      KRS Resource, Kernel & Keylayout: Download
      @minixfreak
      Thats the best I could give to support your RK3368 AP6330 box. Now it is up to you to test. Much luck!
      And please give feedback.
      @dincis1
      I found some time to finish up some things I was already working on.
      To solve your Mele F10 Pro remote. audio issue please flash KRS_1.2.9b_AP6335_resource.img & ugoos_ut4_kernel.img
      Ive tested it with my Skype USB headset. Works perfect to me. Except the stock IR Remote. But you mentioned it already.
      Much fun
      My contributions to the community
      [ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
      [ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
        I like to help and share my knowledge. So no worries.
        That's strange test results! Looks like somthing is not working properly, like a wrong WiFi driver?
        Are you sure that you got a Z4? What's about your network issue? Is it still there. Does your WiFi work now? Did you ever open the box and cheked the WiFI chip label?
        Maybe your box is a Andoer Z4L? Looks exactly the same, but has a different WiFi chip. If so, check my post above and try to flash a different KRS file.
          That's strange test results? Looks like somthing is not working properly, like a wring WiFi driver!?
          Now wifi seems it is working. I could stream a 4gb film in kodi with a 9mbps line without buffering.
          This is mine: https://www.amazon.es/Octa-Core-Andr.../dp/B015DYH1MW
          I'll try to open it
          Thanks for your help and work.
            I'll try to open it
            PERFECT
            Which files did U use to flash your YUNTAB RK3368 box?
              ap6335.
              I used "Z4_RK3368-android_TV(ATV)-by_cOOLio-V2.5_BRE.img"
              You may only view thumbnails in this gallery. This gallery has 4 photos.
                ap6335.
                Makes sense with a AP6335. So it's the same as all other Z4 boxes. But which file did you flash before to get such strange issues and test results?
                BTW ... did you check already the Benchmarks? AnTuTu, Geekbench 4, ...?
                And the biggest file I,m able to stream via Kodi and WiFI (5GHz 480Mbit connection), without any buffering, is a 16GB mkv file. But that's also my biggest file. So maybe there is more possible!?
                EDIT
                And finally ... Opera ATV is only good for browsing to read news, forum, etc. Download will not work at all with Opera ATV. That's also the reason why I add Chrome as second Browser to V2.5 BRE.
                  I flash your 2.5 bre firmware. Anything else. The 4gb file was in internet, not my network and my adsl line is only 9mbps
                  Enviado desde mi Mi-4c mediante Tapatalk
                    Ok I see, than maybe only a bad flash!? Such shit happens sometimes. But finally it works (also via internet). Only that counts.
                      Try "Flash Erase" before flashing..
                        I'll try to flash again to see if antutu get better score
                          reflashed again, and the same bad results. Only 32000 in antutu.
                          I'm going to flash using twrp doing a wipe of all because I didn't find the "flash erase" option
                            Sorry, which partition or partitions I have to check to install the image with twrp?
                            Uboot, kernel, resource, boot, recovery,...
                            When I was in twpr, the tv box power off suddendly.
                            Any other option to try?
                              EDIT
                              Hello Coolio! I have installed your firm. But when I try to install the "medieval keyboard addon" by ES file explorer, I have a message error that shows "Sorry test failed. This feature cannot run on your device". And I use a medieval keyboard.. what can I do to use this feature? Root my device? How I do it? Thanks!!!
