[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
Originally posted by Shomari View Post
Originally posted by flyboypr77 View Post
Sorry to sound like a pain. I tried both versions of Kodi 17.1 and the on that comes with the rom. I guess it might be something wrong with my setup if no one else has had issues. And by "it" i was talking about 17.1. But if there is a fix I would try that. Thanks .
Uninstall and reinstall the firmware (only suggesting this because i this issue has not been reported commonly)
... but - before you do that, try this kodi - http://mirrors.xbmc.org/test-builds/...rmeabi-v7a.apk
It's a test version based on Kodi Leia, it runs pretty good on my boxes when I do tests.
I think cOOLio is using Ugoos as a base firmware so there may be an issue proper. In any event, he'll likely get it sorted if needed, we got his back if anything.
and remember, you're not a pain we do this for you and for fun, so never hesitate to post..
Hello! Im a Tronsamrt Orion meta R68 user. Now, Im running a Wasser firm, because the original firm is a junk. Iḿ very interested in this rom. Can you say me if that is compatible with my device? can you say me if the stuttering problem is solved? and One more question: Is a Marshmallow version? Thanks!!!
mglarosa it's lollipop firmware. That shouldn't be an issue, there's no advantage in running marshmallow with RK3368, if anything there are some disadvantages.
As far as audio stutter, you'd have to check yourself, as this fimrware is targeted for the Z4, while using a base of UT4 stock firmware. Both those devices don't have audio stutter, which is almost exclusively reported by users with R68/i68 and similar devices.
Other than that your device should be fully compatible.
Some users believe that mo123 Nagrace kernel fixes the audio stutter issue on your device. I don't believe this to be true, but you can test and let everyone know your results, the kernel is here:
http://freaktab.com/forum/tv-player-...082#post644082
Originally posted by Shomari View Postmglarosa it's lollipop firmware. That shouldn't be an issue, there's no advantage in running marshmallow with RK3368, if anything there are some disadvantages.
Originally posted by mglarosa View Post
Thanks for you reply!!! i ll test it. Two questions; can you say me if is best to migrate from the wasser firm 64 bit beelink (that is I m using now) to this firm? Internet download is very very slow in my country, and takes one day to download this firm, and I want to know if this is best. And another question: is this a 64 bit firm? Thanks!!!
If you'd like, I can try and post a link of this firmware with a smaller size so that you can download it easier, too. It will be faster than the wasser firmware, but other than that I don't know what performance will be like on your device.
... no, it's lollipop, so it's not 64bit. I can't say if this will be better on your device. Because you know the R68 has audio stutter issues that may be present in this firmware, and since I don't have the r68, I wouldn't know if it's better.
Please post the firm if that isn t a problem for you.I will download and test it. I will post the specs in my devicet, if this help to the community
One more question. How do you will do to post an smaller size of this firm? do you will remove some feature or tool?
Hello! If you don t mind... I t coul be great for me!
It's already compressed as small as it's going to be, so nothing I can do. Good luck!
No, I wasn't going to remove anything, I was going to see if it could be compressed further, but it can't, so just go ahead and download it at this link: https://drive.google.com/file/d/0B32...g1Tk9oM1k/view
ROM (Image/Firmware) for the Z4 RK3368 android TV Box (Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6) stable . fast . clean . leanback . android TV (ATV)My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
Here is a small fix for Kodi V7.x to show the real RK3368 CPU temperature.
Instruction in the zip file.
Download: Kodi_V7.x_RK3368_CPU_temperature_fix_by_cOOLio.zip
Originally posted by flyboypr77 View PostI noticed if you install kodi 17.1 the voice is out of sync.
And in most cases those audio out of sync issues are the reason of of crappy muxed or converted video files.
Sometimes a video engine and its codec can fix those unsync crap on the fly automatically. Others are not.
But the good thing of all Kodi version, since the good old XBMC days. With Kodi you can fix this always on your own.
Here a small how to fix all audio / videos out of sync issue with just a few clicks and testing until the video and audio is sync again.
During the playback of the video file go to 'Settings'.
Then open 'Audio and subtitel settings'
There you will fine the option 'Audio offset'
Now you change the Audio offset +/- in 0.000s steps. ( + ) or ( - ) depends on the way the video is async.
If you hear first the voice followed by the lip movement. use ( - ) offset until it is sync.
If you see first the lib movement followed by the voice, use( + ) offset until it is sync.
And finally ONLY in case all your video are unsync you can save also the offset globally for all videos.
BTW I love this Denzel movie ...Last edited by cOOLio; 04 May 2017, 00:53.My contributions to the community
There are currently 2470 users online. 1 members and 2469 guests.
