link:
[ROM] Z4 RK3368 - android TV (ATV) for Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6
[QUOTE=BEN001;n684403]
You can use this firmware after flashing the resource for 10/100 Mb
link:
http://4pda.ru/forum/index.php?showt...ost&p=58677199[/QUOTE
Sorry new to this. Only flashed firmware in the past & not resource. Can’t read rus either.
Hi everyone I am trying to upgrade to a custom firmware as the stock firmware by Sumvision is very slow and is on 5.1
Can I upgrade firmware I have looked every where but cant seem to find it can anyone help thanks.
Sumvision Android X8 media player, Rockchip 64-bit 1.5Ghz Octa-core CPU, the 8 core
Originally posted by mani man View PostHi everyone I am trying to upgrade to a custom firmware as the stock firmware by Sumvision is very slow and is on 5.1
Originally posted by mani man View PostHi mate I would like to upgrade firmware on my box is there any firmware I can download from here to use on a sumvision x8.
System Config.
CPU: RK3368 64bits Octa core Cortex A53
Operation System: Android 5.1
GPU: PowerVR SGX6110 GPU
RAM: DDR3 1GB
ROM: eMMC Flash 8GB
Bluetooth: BT 4.0
Antenna: Built-in antenna for WIFI
Media
UHD 4KĂ—2K: Yes Support
Full HD 1080P: Yes Support
HEVC H.265/H.264: Yes Support
Video/Picture Decoding Supports:*.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg file formats
Audio format Support: MP3, AAC, WMA, RM, FLAC, OGG
Communication
Ethernet: 100M/LAN
WIFI: IEEE 802.11a/b/g/n
Sensor/Motor: IR Sensor 1*IR
Indicator: Power LED 1* power LED with two – color
Originally posted by mani man View PostI can not get my box into upgrade mode can you please help
https://www.entertainmentbox.com/fir...roid-tv-boxes/
I have an Andoer Z4 rk3368 tv box and I installed the Android TV v.25 BRE firmware, but now the hevc/x265 movies (especially the 4K ones) are badly rendered. The picture is displayed with lots of thin green parallel horizontal lines and the image is shaky.
Here is a sample:
The same behavior regardless of the player (kodi, mxplayer),.
With the old firmware, these files were rendered correctly and without any artifacts.
Could you please advise if there is any workaround for this issue? Maybe a newer version could resolve it?
Thanks,
tlc
There are currently 2190 users online. 0 members and 2190 guests.
