just keep reading and be patient - follow instructions and you should be ok otherwise failures on a working box just mean incorrect procedures.
Solution for stuck in Android load AML8726-MX Dual Core TV Box Android 4.2.2
Originally posted by kerikhaos View Post
=> http://www.freaktab.com/showthread.p...l=1#post236397RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostBecause page could be difficult (e.g. I use 30 posts per page)
download them and your ready to go. If your not seeing the link you need to set your view to default but you can also search for post no. 301 - you will find it there
hi tried but still didnt work, i managed to get it working by downloading stock firmware from here:http://blog.geekbuying.com/?p=15163
and its working spot on, thanks for your help!
Originally posted by watling85 View Posthi tried but still didnt work, i managed to get it working by downloading stock firmware from here:http://blog.geekbuying.com/?p=15163
update....
im suspicious of this firmware as it doesnt begin to auto install on its own - even with manually selecting this file it aborts very quickly.....
its a risky zip file from a not so well known source and im not even sure this is designed for the matricom boards g18ref etc....
use this at your own riskLast edited by kerikhaos; 24 December 2014, 08:16.
Originally posted by kerikhaos View Postoh yeah and i forgot to mention i will be playing with the mag250 emulator for iptv and see how well that works on android just like xbmc if we can get this feature to work well with our boxes we can have the benefit of both iptv mag systems in the comfort of our mx2 boxes
Have you got a link to the mag250 emulator. Also is there a thread or site thats actively testing this out ?
PS great work on the fw brick fix with dexter.
Originally posted by teleast View PostHave you got a link to the mag250 emulator. Also is there a thread or site thats actively testing this out ?
as for testing thread I don't think so but I've had a few hours play on this thing and it has loaded some free listings I found online so I think a subscription is needed to be 100% tested successfully
thanks for positive feedback with the android steps and hope it has helped you with yours
Thanks for the info.
During my tests with faulty MX2 boxes, and it's nothing I've seen mentioned in threads before, is that if you plug an ethernet cable into the back of a faulty box is that the green and yellow lights flash in sequence of 5 flashes. I have a few of these boxes that don't seem to come back to life no matter what, and I am guessing it is a service code. It would be interesting to see if this was the case and help people in knowing wether the box is possible to bring back to life.
need help with g18ref_th10
hi friends
I had from http://www.aliexpress.com/item/Hot-s...019907947.html
an MX2 box
tryed to load new firmware seller sent me g18ref_th10-ota-20140901.V0801 and did it with sucess
But after some settings i did :-) I have loop booting and dont know what to do
I have no reset button in AV socket. I'm sure about it
here is a picture
My China seller send me instructions:
MX2 Update process
1 when you receive the file I sent to you ,please Extract the file on computer desktop
2please compare a 4GB TF card and use computer to format TF card, and then copy the file into the TF card .
3Disconnect the power of the MX2, and then connect the power of MX2 TV BOX with the TF card which has File I sent to you, after there is a screen which has file I sent to you .
4disconnect the power of the the MX2tv box ,take out of the TF card ,and restart it .
It doesn't work for now may be bocouse I use not 4Gb but 2 Gb Microsd card?
Please any help
Originally posted by Thegazmat View PostSo you think TF card its not a microsd card?
Just to use usual Flash stick with 4 Gb???
Ok
Thanks a lot!
4Gb - this is the main thing I think.
Becouse of my device has only microSD and normal USB socket I will use microSD and Adapter card.
I already tryed with 2Gb and even prepared it witn SDcardMaker and my u-boot.bit but seems like my tv-box can not see card during booting and still has a loop boot
So going to find 4Gb
plz i have a problem
hii everyone.. I have a problem, please if anyone know about these issue help me
I have a receiver based android dvb-s2, called prima 6001
after trying upgrading to a new firmware it stuck
no screen at all , tried both with hdmi cable and av cable same result
tried to replce cable and tried on different tv, same result
the device seem turned on, but nothing on the screen.
the new firmware provider adviced me to do what is called hard brick repair by connecting 2 pins from the board so the device boot from the sd card which contain certain files to go to the recovery.
I tried to do that, but unsuccessfully !!
I didn't know which pins to connect ..
any help ??
There are currently 2419 users online. 0 members and 2419 guests.
