I am new in this thread and this is my first post and hope i will get help from the grus, i need help regarding how to root "Matricom G-box Midnight MX2". I received this box yesterday and i want to do root this box, i dont want to install costum rom just root. Can any expert post step by step instruction how to root matricom gbox midnight mx2. Thanks in advance
Solution for stuck in Android load AML8726-MX Dual Core TV Box Android 4.2.2
HELP
Originally posted by asher1997 View PostI am new in this thread and this is my first post and hope i will get help from the grus, i need help regarding how to root "Matricom G-box Midnight MX2". I received this box yesterday and i want to do root this box, i dont want to install costum rom just root. Can any expert post step by step instruction how to root matricom gbox midnight mx2. Thanks in advance
I would keep your box as is and just select if you want to run the android platform on it (matricom / mbox) or stick the openelec /linux build on it for pure xbmc/kodi.
The rooting in my opinion is just an overhyped way of getting problems quicker :-)
half dead box
Hi guys the above box firstly boots up fine and as long as it's connected via ether net it works. The issue is wifi won't work and 3 of the use ports have stopped working. This is what I have done do far<br />
1. Tried to factory reset - the box just powers down and doesn't reset<br />
<br />
2. I have use a file explorer to try to delete old wifi in settings/etc/wifi and replacing with a wifi file that I got from a box on dame firmware that is working - it won't allow me to delete wifi file<br />
<br />
3. I have use benni's magic so card and followed the tutorial to the letter- when I press the reset button the box blue light comes up but I get no display and have left the box sat the same way for an hour- still did not boot with new firmware but still boots up on normal firmware.<br />
<br />
I cannot ftp it as there is no wifi and am at a loss as to what to do next, any ideas? Please<br />
<br
I have tried titanium backup from a working device and that hasn't worked
Is there a way to flash mew firmware from the main screen I.e once it's fully booted?
Originally posted by kerikhaos View Postunless you are planning to do some developing or advanced android playing on the box i would not advise you to root it as it will be more prone for bricking / corrupting when being used.
Originally posted by asher1997 View Posti have Matricom G-box Midnight Mx2 and i am having some problem with some streams it plays but after a second it kicks me off to the main desktop page can anybody help me regarding this issue thanks
Because the actual problem may be different for different users the best fix would be start from scratch again having to reinstall the latest version of kodi (14 helix) and going through the fusion installer and the rest again. The other quicker solution would be to clear the cache (not the data) found in the xbmc program list. The cache may contain some bad files and causing the crashes. Clear the cache (which should be about 20-60mb, the data contains about 300-600mb so be careful what you clear). Then try and start xbmc again and you shouldnt lose your prefs and addons but xbmc should become more stable.
The last option is to clear both data and cache but you will need to setup from scratch again fusion etc etc etc....
hope this info is useful
I have managed to boot mxbox into cwm but that is as far as I can get, I have tried various different roms, matricom, droidtv etc but always get sdcard/update.zip error. I have been at this now for 4 days and scoured the Internet but am getting nowhere, following all the other tutorials such as bennibannasi my box just sits with a blue light and blank screen. Cwm from sd card is the only thing that gets me anywhere and now stuck again. Could someone please point me in the right direction
Sent from my GT-I9505 using Tapatalk
Originally posted by morph1976 View PostI have managed to boot mxbox into cwm but that is as far as I can get, I have tried various different roms, matricom, droidtv etc but always get sdcard/update.zip error. I have been at this now for 4 days and scoured the Internet but am getting nowhere, following all the other tutorials such as bennibannasi my box just sits with a blue light and blank screen. Cwm from sd card is the only thing that gets me anywhere and now stuck again. Could someone please point me in the right direction
Guys i have matricom gbox midnight v2.2 not (gbox midnight mx2) it has blue light and black screen i tried to flash couple times but unfotunately i couldnt copy the midnight recovery sd card image, i spent 7-8 hours each time but at the end it says sd card doesnt have enough memory whereas i have 8gb sd card so any expert can help me and advise me any alternate methode i will be very thankful to them
thanks in advance
Originally posted by asher1997 View PostGuys i have matricom gbox midnight v2.2 not (gbox midnight mx2) it has blue light and black screen i tried to flash couple times but unfotunately i couldnt copy the midnight recovery sd card image, i spent 7-8 hours each time but at the end it says sd card doesnt have enough memory whereas i have 8gb sd card so any expert can help me and advise me any alternate methode i will be very thankful to them
thanks in advance
second you may be preparing the card on a bad platform (windows 8 or higher) or your card reader is at fault.
try changing the two above and try again
hi
ok having some serious problems and at my wits end with it
the box when i plug the power in most of the time just the red light. the odd time the blue light will come on but no picture on tv. Ive tried the toothpick method but anytime i try that the light just stays red and nothing happens.
Now ive tried the HDD image thing and im getting this error
13/01/2015 19:04:59
13/01/2015 19:04:59 HDD Raw Copy Tool 1.02; http://hddguru.com
13/01/2015 19:04:59
13/01/2015 19:04:59 * * * * * IMPORTANT: DURING THE DUPLICATION PROCESS
13/01/2015 19:04:59 ALL DATA ON TARGET WILL BE IRREVERSIBLY OVERWRITTEN!
13/01/2015 19:04:59
13/01/2015 19:04:59 Source: [0] RAW MATRICOM_MX2_115_FULL_AUG_09_2013 (1).rar [595.48 MB]
13/01/2015 19:04:59 Target: [1] SanDisk Cruzer Blade 1.26 [8004.3 MB]
13/01/2015 19:05:27 Locking device...
13/01/2015 19:05:27 Copying...
13/01/2015 19:06:11 Write Error occurred at offset 593,428,480 (87)
13/01/2015 19:06:11 Cannot write to target, aborting...
13/01/2015 19:06:11 Average speed: 13.7 MB/s
13/01/2015 19:06:11 Operation terminated at offset 593,428,480 LBA 1,159,040
i think this is the only way to unbrick it and i cant even get the image on the card correctly ..
can anyone help me with this
There are currently 2993 users online. 0 members and 2993 guests.
