Solution for stuck in Android load AML8726-MX Dual Core TV Box Android 4.2.2
Originally posted by node View PostI loaded a M8 file loaded onto an SD card the file appear to load then abort with this error message. THIS package is for "K200" devices, this is a f16ref. If I can only get the f16REF I think it will work.
you need to use the acemax firmware located in previous posts and detailing which firmware to download. Try to force flash with one of the acemax roms and see if you get a better result.....the M8 is not your box it is the MX2 G18REF. The m8 is the s802 quadcore and has totally different firmware so be careful as you are flashing incorrect roms on your box and may cause additional damages or bricking
UART unsuccesful
Ok my experience with the new 6 pin ttl uart interface over this last weekend was not successful. I am in true believe that this board has had its last days and the problem is now clear that the motherboard has a defect. I will lay this to rest.
Just to confirm my connection to the board was using putty and then the serial COM3 interface (which the driver had been installed on) and set baud rate to 115200 / even the 9600 but still did not connect
just got black screen
just wanted to know if there were any additional configurations used in putty to help connect to the interface. With flashing black screen and no signs of interaction i thought maybe a push here or there on the board to try waking it up (via reset button or pin short). So far had no luck.....will continue trying till end of the week then its bye bye baby. This so far has been the worse condition ive ever seen the mx2 in and i musty say the little bugger is still turning on attempting to boot from something
Originally posted by node View PostWell I just got "black screen" on this box, still have blue light. Any way to get back the box working?
power off and remove sd card.......power on device and wait
Originally posted by kerikhaos View PostOk my experience with the new 6 pin ttl uart interface over this last weekend was not successful. I am in true believe that this board has had its last days and the problem is now clear that the motherboard has a defect. I will lay this to rest.
Other than selecting the correct COM port and BAUD rate then all other settings in PuTTYremain on default.
Originally posted by kerikhaos View Postdownload acemax firmware, prepare sd card......power off, insert toothpic - hold down while powering on and sd card inserted......remove toothpic after 50 seconds, even if no display......wait for 30 mins......
yet another aml8726 bricked ...beyond repair?
Hello guys...
This WAS my "CS818II" box, a typical Chinese Android box with DVB-T2 tuner ...pics and specs here http://www.geekbuying.com/item/CS818...-Black-333400/
A week ago i had this brilliant idea of installing some sort of Linux suitable (...) for AML8726, clicked on upgrade, upgrade started normally from the zip, with a progress bar on the screen, and that was the last thing i saw
The box, dropped dead, in the middle of upgrade.
Blue led always on and black screen ever since
I have NO REAL SUPPORT from vendor, all i have is a guy advising me to "please check the cable" ...
I think you are my last hope to save the box
What i have done:
-Downloaded firmware (4 files, including u-boot.bin, factory_update_param.aml, recovery.img, and the actual .zip) Used the suggested toothpick method, with 4Gb and 8Gb SDcards (FAT32). No luck
-flashed the u-boot.bin into the SDcard usng the AMlogic SDCardMaker.exe, then repeated previous. No luck
-Added in the SDcard u-boot.bin and aml_autoscript found in a post, booted with toothpick, gave it plenty of time, re-booted with and without toothpick, with card containing the usual 4 files from above, and in brief i did all combinations i can think of of booting with SDcards. No luck
Since all those did not work, i found the NAND chip (it's at the back side, not visible in attached screenshot) and short-circuited pind 7-8, or 8-9 or 5-6 during boot. No luck.
Kinda lost and deeply sad, ordered USB-UART at ****, waiting to arrive, but, NO CLUE as to what should i do with that cabe when its here... Not experienced at all with this kind of work
So, main question is, if anyone knows of this box, has some experience, maybe has some ideas.. maybe can help.. Or point me to some UART-guide (how to) ...I read i need some "image" to flash via UART, i have NO SUCH IMAGE, anyone maybe has a link or something...
Any help, deeply appreciated
What i have done:
[ATTACH=CONFIG]10861[/ATTACH]
Your UART connections are near the top right of the heatsink in your picture, read through the last few posts between myself and kerikhaos.
First just see if you can connect via UART and post what you see.
I got the box back up, I cannot get the ACEMAX firmware loaded at all.
How I got the box back up from Black Screen:
Required 2-4gb SD cards
I wrote the image file in post #11 to on one of my 8gb SD card. NOTE if you use an 8gb SD card it will appear as a 4gb after writing this image file to it. You will have to re-partition the card after to get it back to a 8gb. SD. I would advise to use a 4gb card and keep it aside to unbrick your box in the future.
I insert the SD card then the HDMI cable then I held the switch with a toothpick in the AV port and powered the box.
The robot came up, did his thing and fell flat on his back. Next i wipe the cache the robot stood up. I then cleared the user data.
I then removed the SD card and inserted the second SD card which has the MX/G-Box firmware, the box took the firmware and loaded fine.
I know this is not the firmware for this box, but was all I had to get it alive. The reason is I can load Kodi but still getting "Waiting on External storage message" and kodi will not load.
node
make sure there is nothing else in the other usb port and no sd card in the box.and do the toothpick thing, be patient and give it time to boot.
when i was playing with roms, the sd card doesnt play nice, only thing that worked for me is using a usb stick, I know every thing on this site refers to a sd card but for me the usb stick is the only thing that worked.
ive managed to use the wetek CM11(but cant use wifi and the dvbt) firmware on this box.
Many thanks fatfreddiescat & dope101 for reply, bad news usb not working either, uart arrived today, and yes, good news we have a STILL live box ...i think
Here we go:
Code:wetek#EEEE I3000000032940xf100110303;77500EEEE I400000004294_M6_BL1_3431>2534313 TE : 77476 BT : 14:37:19 Jan 29 2015 CPU clock is 1200MHz wait pll-0x03 target is 0204 now it is 0x00000203 DDR clock is 516MHz with Low Power & 2T mode DDR training : DX0DLLCR:40000000 DX0DQTR:ffffffff DX0DQSTR:3db05001 DX1DLLCR:40000000 DX1DQTR:ffffffff DX1DQSTR:3db05001 DX2DLLCR:40000000 DX2DQTR:ffffffff DX2DQSTR:3db05001 DX3DLLCR:40000000 DX3DQTR:ffffffff DX3DQSTR:3db05001 Stage 00 Result 00000000 Stage 01 Result 00000000 Stage 02 Result 00000000 Stage 03 Result 00000000 DDR init use : 42463 us HHH BootFrom SPI ucl decompress decompress true 0x12345678 Boot from int dev 1stSPI RESERVED TE : 1303529 System Started U-boot(wetek@) (Jan 29 2015 - 14:37:08) aml_rtc_init aml rtc init first time! clr h-ram DRAM: 1 GiB relocation Offset is: 105e0000 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 NAND: Amlogic nand flash uboot driver, Version U1.06.020 (c) 2010 Amlogic Inc. SPI BOOT : continue i 0 No NAND device found!!! NAND device id: 2c 64 44 4b a9 0 NAND device: Manufacturer ID: 0x2c, Chip ID: 0x2c (Micron B revision NAND 8GiB MT29F64G08CBABA) 1 NAND chips detected #####aml_nand_init, with RB pins and chip->chip_delay:20 bus_cycle=5, bus_timing=6, start_cycle=6, end_cycle=7,system=5.0ns oob size is not enough for selected bch mode: NAND_BCH60_1K_MODE force bch to mode: NAND_BCH40_1K_MODE aml_chip->oob_fill_cnt =168,aml_chip->oob_size =744,bch_bytes =70 multi plane error for selected plane mode: NAND_TWO_PLANE_MODE force plane to : NAND_SINGLE_PLANE_MODE aml_nand_init:oobmul =1,chip->ecc.layout->oobfree[0].length=16,aml_chip->oob_size=744 aml_nand_scan_bbt: NAND_MFR_MICRON NAND detect factory Bad block at b400000 and block =90 and chip =0 NAND_MFR_MICRON NAND detect factory Bad block at b600000 and block =91 and chip =0 here 3 step : oob error: block 4086 here 2 step : key valid: block 4088 here 2 step : key valid: block 4090 here 2 step : key valid: block 4092 aml_nand_scan_bbt: factory Bad block bad_blk_cnt=3 aml nand env valid addr: ffffffffffe00000 ,status =0 aml_nand_save_env:5915,save env to 0 key start_blk=4088,end_blk=4095,aml_nand_key_init:684 aml nand key valid addr: 1ff000000 aml nand key valid addr: 1ff200000 aml nand key valid addr: 1ff400000 aml nand key valid addr: 1ff600000 CONFIG_KEYSIZE=0x10000; KEYSIZE=0xfffc; bbt=0x1330; default_keyironment_size=0xeccc i=0,register --- nand_key NAND bbt detect factory Bad block at b400000 NAND bbt detect factory Bad block at b600000 NAND bbt detect factory Bad block at 1fec00000 Creating 2 MTD partitions on "nandnormal": 0x000000800000-0x000001000000 : "mtd1" 0x000001000000-0x000008000000 : "mtd2" nandnormal initialized ok detect mx chiprevD :1 and nand_type: 40 nand_curr_device =1 SPI BOOT,spi_env_relocate_spec : env_relocate_spec 53 SF: Detected MX25L3205D with page size 256, total 4 MiB SPI NOR Flash have write protect!!! In: serial Out: serial Err: serial register usb cfg[0][1] = 9fe85ad0 Net: Meson_Ethernet init suspend firmware done. (ret:0) efuse version is not selected. Hit Enter key to stop autoboot -- : 0 exit abortboot: 0 Amlogic Ethernet Init Success: reset mac OK!(0) ETH PHY hardware reset OK find net phy id=0x2430c54, phyad=0 set_mac_mode(0) final_addr[rx-tx]: 0x9feec000-0x9feec600 Ethernet reset OK MAC address is 00:00:00:00:00:00 phy auto link failed half duplex 10m *** ERROR: `ethaddr' not set phy auto link failed Wrong Image Format for bootm command ERROR: can't get kernel image! wetek#
Originally posted by Αντρέας View PostMany thanks fatfreddiescat & dope101 for reply, bad news usb not working either, uart arrived today, and yes, good news we have a STILL live box ...i think
Here we go:
You have console, have you tried to send it any commands, type 'help' for a list of recognised commands.
Do you get any different data in console if you use toothpick and also with and without the SDcard?
Mine was showing that it was stuck in a loop looking for something on the ethernet port, yours just looks like it has not found the kernel image and doesn't know what to do from there.
Yes fatfreddiescat, we have console, we have commands, i will try fatload mmc 0 and then bootm see if i can get recovery ... and yes, i do not know what i am doing, just reading (carefully) pages uppon pages in forums and trying to learn lol so any ideas that might help are always welcomed hehehe
There are currently 2062 users online. 0 members and 2062 guests.
