MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/16GB Dual WiFi Fast Lan BT4.1
A couple Bucks Discount
3+16G coupon: GBM8SP3
GearbestLast edited by superceleron; 07 April 2018, 00:44.
Today we can have a look at the MECOOL M8S PRO TV Box - 3/16GB
Let me just Vent about this box, it has lots of Vent as you will see
MECOOL M8S PRO, Amlogic S912 CPU: Android 7.1.1 ARM Cortex-A53 Core: ARM Mali-T820MP3 RAM: 3/16GB RAM Type: DDR4 ROM: 16G
2.4 and 5GHZ WiFi: Bluetooth 4.1 HDMI Version: 2.0 Fast Lan.
Top View
Underside and Vents good to see.
WiFi Chip
Ram
eMMC
MECOOL M8S PRO TV Box - 3/16GBLast edited by superceleron; 07 April 2018, 00:44.
A look around UI and System information and some Benchmarks
A couple of quirks
When adding apps to Home Screen Favorite, after a reset they remove themselves
The TV Centre App what ever that is (KODI) also not installed at present...Found
Found TV Centre In apps needs to be installed so all good Looking like Kodi 17.1
As I say Early days, Ui is fairly smart and snappy looks OK.
UI: Standard Mecool
Android 7
DRM
Ram and Storage truth
Memory Read and Write
Vellamo
CPU-Z
A1 SDBench
GeekBench 4 Compute and CPU Scores
Full Details > http://browser.geekbench.com/v4/compute/670088
Full Details > http://browser.geekbench.com/v4/cpu/2584903
3DMARK
Bonsai Benchmark
OTA update thing
An update today has resolved the adding of Apps on the Home screen all fixed
Running Kodi 17.3rc as their TV Centre working fairly well with most of the Demos I tested
Netflix Ok and Plex as usual
Starting to get more of a feel for Android 7, more Secure, and new setup to get ones head around
Thanks for the review and updates trebor.
I also have this box, it came last week from Gearbest - I like it but have some issues with mine:
1. Ethernet port is broken, it will get connection but it does not locate the lead properly and over time it works loose.
2. SD-card reader is set a bit too far back so I have to use a knife or something similar to lock it in place and release it - not that bad just a slightly annoying haha
3. Home screen issues as yourself - does not keep settings, in fact if I choose a new launcher it overrides it on start also.
Can I ask what version software you are now on trebor?
You mentioned an update received but I have yet to receive one since I have had the box through the OTA updater app, I am on OTA Version: 91220001.
Cheers, Bob.
There are currently 2439 users online. 2 members and 2437 guests.
