Can I use usb drive instead of sd card for OTA update from current rom it self?
MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/16GB Dual WiFi Fast Lan BT4.1
Hi. I’m new here and yesterday my box came. It’s this one:
https://m.geekbuying.com/item/MECOOL...te-403024.html
I think it’s all the same like topic title but with android tv os.
Just a few questions:
1. Does hdmi cec work with you. Mine doesn’t, already tried few diferent cables, nothing. My tv support it becouse with rpi3 cec worked fine.
2. Can i flash just via ota update magendanz rom for our device that isn’t android tv os but regular android os and for examlpe revert back to atv without losing drm, widevine level 1?
Thanks in advance.
Originally posted by Lolos21 View PostHello. I have M8S PRO 3/16GB with 20170817 f/w. I bought M8S PRO 3/32GB and it has newer f/w. I want to downgrade via USB Burning Tool but I can't because my new M8S PRO doesn't have reset button! Can I downgrade the f/w without USB Burning Tool? Please help me!
2. Another solution is to make a backup on your old box with TWRP and then to do a restore from that backup on your new box using the same TWRP.Last edited by lyubodelev; 01 November 2018, 22:06.
Originally posted by lyubodelev View Post
1. Try to brush the box without reset button. Just pull out and then again pull in the USB cable if an error occurs.
There are currently 4337 users online. 0 members and 4337 guests.
