MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/16GB Dual WiFi Fast Lan BT4.1
Originally posted by SakisL View PostCan someone help me step by step how to do it because I have no idea?
1. Download the file m8s_OTA_20180205.zip. 2. Dump the file on the SD Card preformated at fat32 preferably on the Box. 3. There is a small hole (reset through a paper clip) on the bottom of the Box. Press the clip button inside the console and hold it. 4. Plug the console into the socket. After the Mecool Screensaver we get to Recovery. Release the clip from reset. 5. Select the update from EXT -> update from sdcard -> yes option in the menu. After installing the firmware, reboot the console - Reboot system now. The second way: go to the Update. Select Local Update, find the firmware on the SD Card. Press Update Box itself reboot and will prefix the console.
hello i'm new in this forom ..
i just bought the box m8s pro 3 / 32gb is i have two problem:
1- the play store tells me the error (incompatible application) and I want to change the paly store for all Android devices and I did everything to install but failed.
2- I have a Sony Bravia 40kdl400 and the problem that every 15 min it displays colors pink / green /
here are my two problem help me please
sorry for my bad English
Originally posted by waelbouss View Postmy box just m8s pro not L or w juste m8s proMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by waelbouss View Postthis frim for m8s pro and i want update without pc
2. And where did you see PC - only to download the suitable files. If it is more easy for you - download them with your box!
Originally posted by waelbouss View Postplease the link for m8s_OTA_20180205.zip
Everything you do with your box is at your own risk!
There are currently 1800 users online. 1 members and 1799 guests.
